Question about Largan Chameleon Mega Digital Camera
Won't work with XP
I can't get the drivers to install! It doesn't show USB port Just COM1 and something else
  • Gamernotnerd Jul 08, 2008
    Ooops I missed the Start Menu shortcut... Now it just gives me "Device Not Ready"
  • 2,985 Answers
You do not drivers or any other sfotware for Win ME/ XP/Vista to see the camera.
Remove any software you have loaded and let Windows do the work
Posted on Jul 08, 2008
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
Hi, I have Olivetti PR2E. Now i am using notebook, so there is no serial port at my notebook. Then i bought the usb to serial port cable. I add printer (Generic/text) cannot printing out. then i install...
Hi, what your system detecting is that the PR2E still in COM1 or COM2, if you have the driver installer set the port to USB so that the system will detect your printer via USB. Or change the port access from COM1 to virtual USB.
Jun 22, 2011 | Office Equipment & Supplies
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
Problem with serial connection with AMD motherboard
Software that accesses serial ports usually allow you to specify WHICH port you want to connect via.
Your new board should have COM1 and possibly COM2... but perhaps your old setup was running from COM3?
Connect the Casio to COM1, and check the software you are using... set that to "look" at COM1 also. That should work!
Apr 20, 2009 | Casio Serial RS-232 Cable (CELL-300)
ERR: C2 driver
Look for an executable file on that folder and try to install usb driver
Aug 17, 2008 | Toshiba e-Studio163 Copier
Print with usb cable
when you install the driver, don't connect printer yet to pc. wait for a prompt for you plug in the USB cable so that it will create its own usb vitual printer port, so you mean when you go to printers and faxes, right click on your printer and go to properties then ports, which port has a check mark? it should be usb001 or something then usb virtual printer port.
USB port
Make sure you are using a direct cable, not an adapter( usb to serial or vice versa) if you are using a serial cable, make sure your printer is the only one using the com1 port, this should be free...
check and go to command prompt- click on start then on RUN put in cmd then press enter, on black window type dir >com1 then press enter. it should print if its free. other wise go to device manager, delete com1 or uninstall then reboot computer so that it will reinstall the com1 driver back to computer.
keep me posted
Largan Chameleon Mega Digital Camera Logo
Top Largan Cameras Experts
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Largan Camera Expert? Answer questions, earn points and help others
