Question about Lightolier Sunrise Preset Incandescent Dimmer Zp600-br
Zapped my sunrise zp600 with a big static charge from my finger. Dimmer seems to be fried. My main questions regards running a dimmable cfl with this switch. Have been doing this for several years with no problems but wanted to check before I replace the switch. Thank you
4 Suggested Answers
  • 107 Answers
SOURCE: I have installed the Maestro
Maestro dimmers are not recommended with any CFL for pretty much the reasons you are experiencing. The electronics within the CFLs are probably not letting the power circuitry in the Maestro charge-up - and because of that, it comes as no surprise that adding an incandescent lamp solves the problem. The company makes products that are compatible in their Ariadnia/Toggler & Diva product families, but not Maestro - you just need to make sure the dimmer itself identifies itself as compatible with CFLs.
Posted on Dec 30, 2010
dgw1
  • 19 Answers
SOURCE: I would like to replace
The zp600 is the master, and the zpr-3 is the remote. With only one location you need to use the zp600. For multiple locations, you use the zp600 at the load side and zpr3's at other locations with all the yellows hooked together, and all the blacks hooked together except the black going right to the light. This hooks to the red at the zp600
Posted on Mar 08, 2011
dgw1
  • 19 Answers
SOURCE: What Dimmer can I use
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Posted on Mar 09, 2011
Must I replace its 100 watt Sylvania incandescent bulb with another incandescent? What about an equivalent CFL or LED bulb?
Both will work fine as long as the light isn't on a dimmer. You can't dim CFL bulbs.
If you do have a dimmer, you can dim LED bulbs as long is you buy dimmable LED bulbs.
Which LED bulbs are best for built in dimmers CNET
Dec 29, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
Can I use a dimmer switch with light bulbs whose packaging makes no mention of whether or not the bulb is "dimmable"? (be they incandescent, CFL or LED)
Most old dimmer switches do not work with energy saving/led bulbs, they will work fine with the old style filament bulbs, the newer dimmer switches will be compatible with energy saving bulbs and will indicate on the packaging!
Dec 27, 2014 | Electrical Supplies
Compact Flourescents won't work in ceiling fan
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
Dec 17, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunt dimming fd
Ok - a couple of things, first - when a dimmer is set to minimum; zero to a barely perceptible level of light output is expected. Second, fluorescent lamps have a much shorter range of dimming that the standard incandescent lamps have. It is not unusual for a fluorescent lamp to remain off until the dimmer is at or above the half way point in the dimmer's range. Third, you can not dim a fluorescent lamp or fixture unless the lamp or fixture is specifically labeled as being "dimmable". Use of a dimmer to control brightness of fluorescent lamps and fixtures that do not clearly indicate they are designed for dimming or to control the speed of motors like those in "paddle fan & light fixtures" creates a dangerous fire hazard condition. Most CFL (compact fluorescent lamps) that readily replace the screw-in incandescent type lamps and are clearly labeled as dimmable, can be used with a standard dimmer. The traditional (non-CFL) fluorescent fixtures that have a internally mounted and hard wired internal ballast need a special dimmable ballast to operate.
Feb 02, 2012 | Philips Electrical Supplies
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
I would like to replace my lightolier zp600 dimmer to a zpr-3 that has the same wire wiring diagram as a zp600
Feb 15, 2011 | Lightolier Sunrise Preset Incandescent...
I have installed the Maestro dimmers with the recommended CFL dimmable bulb but when i turn on the power the dimmer cycles up and down and dosent stay on. i have installed one incandescent light in a room...
Dec 20, 2010 | Maestro Electrical Supplies
We want to replace our bathroom exhaust fan. We like the Harbor Breeze 'Rosemont' model at Lowes. It's a decorative combo fan/light unit. The unit is equipped with 2 13 watt (60 Watt incandesant...
It does not matter whether you turn on the switch or the switch is motion
activated, the light does not know who turns it on.
The switch must be designed for florescent.
What do you mean by proper base, you have a single gang wall box,
that's a box inside the wall, with the electric and a switch,
The gang could be single or hold 5 switches, which ever is installed.
Most all switches fill fit into any gang box.
Feb 08, 2010 | Dryers
Flashing lights instead of shutting off
14 years does seem like a reasonable life span for a dimmer. My suggestion is to turn the circuit off, take the dimmer out, wire nut the two wires together, turn the circuit on. If the light comes on normally get yourself a new dimmer ($10). Make sure to turn the circuit back off before installing the new dimmer.
Jan 15, 2009 | Lightolier Sunrise Preset Incandescent...
Open Questions:
See all Lightolier Sunrise Preset Incandescent Dimmer Questions
Lightolier Sunrise Preset Incandescent Dimmer Zp600-br Logo
52 people viewed this question
Top Lightolier Electrical Supplies Experts
ken skalski
Steve
Tom Chichester
Are you a Lightolier Electrical Supply Expert? Answer questions, earn points and help others
