Question about Lexmark X7350 All-In-One Printer
Usb Port I have a Lexmark x7350 and been lots of problems finally found out the usb port in the back of the printer has gone bad. Does anyone know where or if its fixable. I sure hope so I havent had printer but maybe two years, been a great printer would hate to be without it best ever. Please help!!!!!
  • Lexmark Master
  • 4,338 Answers
You can download the service manual from this site, after you register. I beleive it is free:
http://www.nodevice.com/manual/newmans/lexmark/4418smpdf/get21358.html
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 02, 2008
How can i conect a printer
Your printer came with a USB to mini USB cord. The mini end plugs into the back of the printer and the USB into any USB port on the back of your computer tower. The computer will recognize new hardware and walk you through install. murf427
Aug 30, 2012 | Lexmark X7350 All-In-One Printer
Where does it plug in to pc
Your printer must have a USB cable like this one (some printer come without one so you need to buy it):
The square connection on the USB cable goes into this port on the printer:
mariolands_35.jpg And the other bit goest into the USB port on the computer:
Feb 24, 2011 | Lexmark X7350 InkJet Printer
My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
My lexmark x7350 won't scan, it says failed to retrieve application, what should I do?
Try launching the scan from the computer. You may not have the monitor program running properly or you may need to reinstall the full feature software from http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_X7350&segment=DOWNLOAD&userlocale=EN_US#1 (select your OS). Uninstall and then reinstall; this will cure problems with the driver/software missing dlls.
Try a new data cable and a different port. Try a direct connection if you use a USB hub or print server. (Two-way communication is needed for the scanner to work.)
I hope this helps.
Jun 14, 2010 | Lexmark X7350 All-In-One Printer
Windows does not start when I leave my printer plugged in
First if your USB cord is too long try to switch it out with a smaller cord. If that does not work please unplug printer boot up and enter the BIOS settings.
http://www.michaelstevenstech.com/bios_manufacturer.htm
Then check to make sure your boot sequence is setup to Hard Disk first and not USB, you need to make sure the USB Boot Device does not have priority over HDD.
Finally make sure that USB Emulation is not turned on in the BIOS.
If all of the above does not fix the issue you may have a faulty USB port or a bad mother board.
Jan 17, 2009 | Lexmark P4350 All-In-One InkJet Printer
Cannot locate the usb port on the back of my new x7675 printer
The USB port is on the back bottom left as you have the back facing you. That USB port is for connecting the printer to the computer. It looks like a small oval port and it is the only USB port on the printer.
Thanks, Joe
Nov 29, 2008 | Lexmark Office Equipment & Supplies
Lost manual
There is no much to hook up, you hook up the RJ11 phone connector at the back of the printer to the phone line.
Install printer software onto the computer.
Then connect printer to computer using USB cable.
See here , there is user guide for all x7300 series:
User's Guide
see also
Lexmark X7350 Top 20 Questions
Here also notes on how to set up fax
Lexmark X7350 - fax problem
Sep 08, 2008 | Lexmark X7350 All-In-One InkJet Printer
USB cable
that's really and truly weird. Which end of the cable are you having trouble with. For this printer, the end that fits into the back of the printer, is more square, than long. The other end is the USB side. Do I have this correct, regarding the cable?
Feb 16, 2008 | Lexmark X7350 All-In-One InkJet Printer
How Can I Fix Problem
Open your printers folder and make sure you do NOT have a bunch of duplicate installs. If you do, delete them all and then install just one. Be sure you have a good USB cable. Try using the same cable on some other USB device that usually works. If that device wont work with the printers USB cable, its most likely a bad cable. also try using a different USB port. I have seen a lot of computers that have a problem with USB ports suddenly dieing for no apparent reason.
Feb 11, 2008 | Lexmark X1270 All-In-One InkJet Printer
Software and using Lexmark X750
there are not many connections for this printer.. when u say "I need to make sure the printer is connected right". U need the power supply to be plugged in. The usb from the printer to the comp. and the telephone wire from the wall outlet to the "Line" jack behined the printer.. if u have an answering machine.. then connect it to the ext port on the back of the printer.. set the answering machine to 3 rings and X7350 to 5 rings... thats all about the connections... If u dont have a driver CD... then download the drivers from www.lexmark.com for vista
Sep 19, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X7350 All-In-One Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
