Question about JVC Electronics - Others
I am not getting power to my JVC FX-333 BK Tuner. Any suggestions?
    Problem Solver:
  • 5 Answers
Are you sure you have no power? You may have power but It could be that your LCD display does not illuminate.
It is difficult to tell since there are no independent lights or LEDs to tell you whether the unit is ON or OFF.
The FX-333 uses two 12V lamps to light up the LCD display. On my unit they were both burned out. Replacing the lamps allowed me to see that my unit actually does turn on, but only the LCD display wouldn't light up.
Try testing the two lamps... Both plug into a white 4 wire socket near the middle left side of the main circuit board.
Posted on Nov 11, 2016
The same thing happened to my FX-333 right after the new year. Hmmmmm Thing is dead as a door nail.
Posted on Jan 10, 2011
I have a JVC XU-301 BK...When i play MD i get some static disturbance in my audio out put..however when i play Audio CD it workd fine and out put is cleare
I'd suggest you get a MD head cleaner or give the MD head a blast of comporessed air, also check your MDs. If someone gave you a dirty MD the disc can have dust in the case which does exactly what you are talking about.
If you get the MD head cleaner use it sparingly or it will wear the head out (MD cleaners come in sets of two one for the upper head the second for the lower head). You can find them on eBay.
Jan 12, 2014 | JVC XU-301BK 3-CD/1-Minidisc...
Im trying to hook my standard antenna up to my jvc av 56p585. i dont have manual. and i cant get any channels. what do i need to put my tv on to get my basic local channels
This JVC TV has an NTSC (analog) tuner. So it can only receive some of the few remaining low power tv stations that are still using analog transmitters. Depending on your location, you may not have any of these stations within the range of the antenna.
You need an digital-to-analog tuner to get additional channels. Use tvfool.com or antennaweb.org to check for stations in your area and the appropriate direction to point that antenna. (You may need an amplifier since digital stations are either sufficient signal for the tuner to use or you get "no signal".)
Please note that the d-t-a tuners that were available with the government coupon cards only handles standard definition signals (480i). The HD tuner digital to analog converters are available at some online sites but cost more.
I hope this helps.
(you can use a tuner in your computer (USB or PCI card), but you will need a converter unless your video card can put out a signal other than RGB. The HDMI port on the TV will not interface directly with a computer.)
Nov 06, 2010 | JVC Televison & Video
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
WHITE DISTORTED SCREEN
U Main Tuner signal board is dead.Replaced the Main Tuner board will solved this problems.Picture was white distorts,he should of replaced the Main Tuner board.The T-con control board only replaced when u have power to tv,but no video.When have any kind of video on the tv all it way cause by Main Tuner signal board.
Mar 17, 2010 | Televison & Video
Instruction manual
Trying to use the computer controlled JVC AM/FM Tuner Model FX-333.
I am attempting to use the pre-set stations desired for listening pleasure, but I have not been successful. Can you help me?
The FX-333 Tuner is linked to the AX-R441 Amp.
May 22, 2008 | Audio Players & Recorders
Power board for jvc hd52g886
you can try removing the 3wire plug that runs to the ATSC tuner (1orange wire 2 white wires). This will tell you if the tuner is causing the shutdown. This is a common problem.
Apr 03, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at FAIR1968LANE@aol.com and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
Feb 01, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
Internal TV Tuner card(Techom brand) capturing problem
try to use your graphic card on a different pc and use the same methond and check whats gonna happen after wards solution to this it`s either your mother board or ur graphic card
Apr 29, 2007 | XFX GeForce FX 5200, Graphic Card
Electronics - Others Logo
518 people viewed this question
Top JVC Electronics - Others Experts
Are you a JVC Electronics - Other Expert? Answer questions, earn points and help others
