Question about Marshall Health & Beauty
Have a model f-89 and the finger wrap is split and I can't get a reading.
How to open front grill on LG split ac Model No:LSA3ER3N
If it lg might have pull down filters in grount of the unit two fingers pull down the middle of the grill botom
Jun 06, 2015 | LG LS-L1210CL Mini Split Air Conditioner
How do I open battery compartment & install batteries in ChoiceMMed Oxywatch CF309 which is a Pulse Oxymeter
I have the same model. Flip unit ove so you can see bottom. Hold your thumb on the side with the arrows (but don't wrap your thumb around too much. Just enough to hold that side.) Hold the other side with your index finger. Squeeze thumb and finger together while pulling back towards you on Thumb side. Hope that helps.
jim
Feb 07, 2015 | CHOICEMMED OxyWatch CF309 Pulse Oximeter
Split screen on Apple IPad please help
Is the keyboard split? I haven't heard of a split screen in iPad before. If it is the keyboard, just use 2 fingers to push the sides back together.
Oct 16, 2014 | Apple iPad 64 GB WiFi
I have an LG LAN126HNP model and it will not go in to heat mode. Any advice?
perhaps the reversing valve coil is burnt out. Trace the wires by sight from the terminal block that actually go to the RV coil. By using a ohms meter check to see whether the coil is open circuited. If you have no reading on your meter when you first connect it, then the coil will have to be replaced. dont forget to turn off the power before you stick the fingers in the works. Col. www.digitalcontrols.com.au
Mar 04, 2011 | LG Art Cool LA121HNP Split System Air...
How do you change the battery on the Sportline, fitness pedometer 360?
The battery hatch is at the bottom of the pedometer. Just slide the hatch open with your fingers and then pry battery out. Put in the new battery in the same orientation (positive up on most). I find shaking the pedometer works to get the battery to fall out. If my fingers don't move the hatch, I use a small flat blade screwdrivers.
I hope this helps.
(on my pedometer (a similar model) the hatch is on the back with a slot to slide in a finger nail and wraps partway around the hinge)
Aug 08, 2010 | Sportline 15 Function Total Fitness...
Craftsmen garage door opener 139.53919 door spring split in two and garage door will not open
Have someone out to fix the spring.
DON"T fix it yourself. These things are very dangerous and can cut off fingers or worse. Just Google replacing garage door springs to read up and the danger replacing these can be.
Have someone who know what they are doing fix it.
Jan 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Fredy 2 I am trying to play chords with my fingers, there is no sound, if it is on any other mode the chords work but i need it to be on fingered mode thanks doreen
OK... It wasn't clear from the original.
Sometimes the keyboard has a mode that splits for upper and lower part of the keyboard, usually splitting at the F#/G. Also CERTAIN voices will ONLY sound one note at a time. Piano setting would not have this problem of course.
When you play a single note does that sound? If it doesn't in the fingered mode, then there may be a processor problem in the unit/
If it does, there is probably a problem in the matrix that scans the keyboard electrically. If one of the keys were ELECTRICALLY stuck on, the processor within could not read whole sections of the keyboard.
To troubleshoot the problem, press exactly one key at a time... do they all work for say a piano voice while in the fingered mode.
Next press a key at the high end of the keyboard and try others. See if you can find an octave that fails to work.
The problem is likely imbedded in the electronics and could be anything from a dirty key contact to a cracked circuit board. It is NOT likely you can fix this yourself unless you are experienced in electronics.
Sep 28, 2009 | Casio Music
Screen is half Black
The ribbon cable that controls the screen is damaged (or the liquid crystal has baked out... tis happens when the unit is exposed to high temps or long periods of direct sunlight). From my experience w/ these calculators they cannot be repaired.
Sep 11, 2007 | Texas Instruments TI-89 Calculator
Health & Beauty Logo
196 people viewed this question
Top Marshall Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Marshall Health and Beauty Expert? Answer questions, earn points and help others
