Question about Nintendo GameCube Console
My Nintendo Gamecube received a big powersurge and now it won't turn on. Is there any hope for it or is it fried ?
    President:
  • 894 Answers
  • No Power
    1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
    3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
    4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
    5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
    7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
      If this fails, try resetting the AC adapter.
      1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
      2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
      3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
        • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
        • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
    8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
  • Posted on Aug 18, 2011
    Wii controller won't work with gamecube game in wii console
    Gamecube games don't have the proper coding installed on the discs in order to receive commands from the Wiimote. You'll have to have a Gamecube controller to play Gamecube games even on the Wii console.
    Nov 23, 2011 | Nintendo Wii Console
    My gamecube disc's won't spin at all it makes a weird noise after a couple of seconds too.
    Well maybe the motor might be shot or the lens is out of anglement then. Buy a wii instead because wii's are better than gamecube are.
    Sep 27, 2011 | Nintendo GameCube Console
    My Nintendo Gamecube seems to reset by itself about every 30 minutes, can anybody help?
    If the power shuts off during game play or resets after 30 minutes after the system is turned on then turns off and won't turn back on or the fan isn't working, the system needs to be repaired then. This problem that you have might be the fan thats causing this problem then.
    Jan 08, 2011 | Nintendo GameCube Console
    Wii will not power back up after sudden power loss any way to reset
    This could be bad, also could be good.
    1. Check your power outlet and make sure if you have a powersurge protector, that it hadnt tripped. If it is tripped, there is in most cases a button on the side of the powersurge protector for a reset.
    2. In the case that this was not on a powersurge protector, try moving the Wii to another outlet and try it from there. If that doesnt work, buy a new power cable. If the new Cable doesnt work, the Wii is most likely Fried and will not be able to be operational again.
    DrakeTech
    Dec 24, 2009 | Nintendo Wii Console
    No power The light does not come on. The game does not turn. The fan does not blow.
    • No Power
    • Power Light Shuts Off
      If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
    Dec 21, 2009 | Nintendo GameCube Console
    I need the instruction manual for gamecube cabelas big game hunter 2005
    Hi buddy please download the gamecube manual from the following link.
    http://74.125.153.132/search?q=cache:_eFyJy4sLJcJ:safemanuals.com/user-guide-instructions-owner-manual/NINTENDO/GAMECUBE-CONTROLLER-WAVEBIRD-WIRELESS-_M+manual+for+gamecube&cd=3&hl=en&ct=clnk&gl=in&client=firefox-a
    I guess it will help you out. Plz rank me .
    Sep 22, 2009 | Nintendo GameCube Console
    My gamecube has problems with reading all my games
    did you check the back of all your discs for scratches thats the problem or gamcubes broken down if you try a new game and it does the exact same thing send your gamecube to nintendo for repair hope this helps.
    Dec 20, 2007 | Nintendo GameCube Console
    System error
    maybe it has just worn itself because it is quite a old console , hope i helped
    Oct 17, 2007 | Nintendo GameCube Console
    Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
    If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
    Oct 13, 2007 | Nintendo GameCube Console
    Nintendo GameCube Console Logo
    69 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
