Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
When i put in the fabric softener and run a load there is water filling the bleach and fabric softener compartments when the wash is completed. That did not happen in the first few years I owned the washer. Is there something I need to clean?
That same thing happens to mine. You can take the whole little drawer out and empty the water. I don't know why it does this to begin with, but obviously you don't want to leave the water in it so there is a button behind the back end of the "detergent" holder spot, push down on it and pull out the drawer. Then just empty it and slide it back in.
Posted on Jan 09, 2011
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener compartment
You will need to clear the line from the fabric dispenser to the tub.
Oct 15, 2012 | Kenmore HE2 Plus Front Load Washer
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
The compartment that you put the soap in sometimes fills with water when the load is finished
THAT MEANS ONE THING. REMOVE IT AND RUN IT IN WARM WATER, CLEAN IT OF ALL SOAP FILM AND ETC. ON THE SLOT FOR THE BLEACH AND FABRIC SOFTENER, FILL WITH WATER TO THE MAX LINE, LET IT SETTLE, THEN ADD WATER TO IT AGAIN AND SEE IF IT FLOWS THROUGH DOWN TO THE BOTTOM OF THE DISPENSER.
Aug 04, 2010 | LG WM-2077C Front Load Washer
How to use fabric softener
On this machine the compartment is built to hold your softener until it is time to be dispensed. So put in your softener (and bleach if you are using it) at the beginning of the load when you are adding your detergent. The washer will flush the fabric softener cup during the rinse fill to make sure it comes in at the right time for you.
Hope this answers your question!
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Jun 18, 2008 | GE WBVH6240F Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
87 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
