Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
We have a toyostove laser 73, we have concluded that the fuel is not getting to the burner from the fuel pump. ok from tamk to pump.
  • 674 Answers
First try pressing the float reset on the fuel sump. If you hear the float drop then it was latched up and now you should be ready to go. If that wasn't it, turn off the valve at your oil barrel and check the filter if you have one and check the strainer in the fuel sump. The strainer is located on the right side of the heater at the bottom. 2 screws hold the cover for the strainer on. Let me know what you find if this doesn't get you going and if it does get you going, please rate my answer and give testimonial.
Posted on Jan 01, 2011
New fuel pump.removed fuel line to burner ,turned unit on very small amount of fuel beinng pumped
Don't forget, the pump does not turn on for 60-90 seconds after the unit starts as part of the start up purging cycle
Mar 07, 2015 | Rinnai Toyostove Direct Vent Heater:...
WHY WOULD THE BURNER GASKET AND IGNITER GASKET BE DRENCHED IN FEL ON TOYO 73, COULD THIS ALSO BE THE CAUSE F NO FLAME IN CHAMBER WINDOW WHEN I TRY TO FIRE IT UP?
If you have too much fuel in the burn pot then you are getting no ignition. Repeated tries to get it to start just dumps more fuel into the pot.
Feb 24, 2014 | Rinnai Toyostove Direct Vent Heater:...
My toyp laser 73 is displaying ee2. we have fuel, what should I look for.?
Check for flame / ignition... if no flame, check igniter: after unit is turned on, the igniter should get hot - CAREFULLY feel the area where igniter is mounted to burner. If it's not hot, your igniter is bad, needs replacement.
If you have ignition, the flame rod (sensor) may be defective or need cleaning.
This document might help...
http://www.rural-energy.com/publications/catalog/documents/document-334.pdf
Feb 15, 2011 | Rinnai Toyostove Direct Vent Heater:...
My fuel line got air in it when I changed my tank line. I bled the line and verified fuel to the monitor and then to the pump. When I tried to start it the pump runs (clicks) but the burner will not fire....
If the fuel pump is making that ticking or thumping sound, it isn't getting fuel to it or the fuel is coming in so slowly that it can't keep up with the pump. Check the strainer in the fuel sump and check inside the fuel sump. There is screen on the end of the fuel pump also. If you have a filter at your fuel tank, it may need to be changed.
Oct 28, 2010 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73 displays ee 10. Toyo is brand new, no obstructions in flue, fuel tank is a good height, only pressed red button once for a second, blower fan works.
ONCCON,
EE10 is not good. This means you had a flame in the pot when there should not have been one. The red button is to be used very carefully. One time for one second. I think you have pushed the button too much and got a fair amount of fuel into the burner. Without pushing the red button try the stove again. If you burn out the fuel in the burner the stove will operate normally. If the code continues I would look at the hook up for the air and exhaust to be sure they are correct. If they are backward it can cause an EE10.
Keep us posted,
Tom
Jun 01, 2010 | Rinnai Toyostove Direct Vent Heater:...
Low heat output. Older Laser 72. Does something
It's likely that the burner mat has came loose or it has a lot of carbon buildup in the burner. Look at the flame when the heater is on. It should be mostly blue with slight yellow tips. You might need to clean the fuel nozzle also. You can remove the fuel pipe where it connects to the burner and use a piece of wire or an allen wrench that will fit in the nozzle that goes into the burner to remove any carbon that may have built up. You can also clean the burner but don't destroy the mat in the bottom. You can find the owner's manual at toyostove.com and it will give you some more things to clean.
Apr 17, 2010 | Rinnai Toyostove Direct Vent Heater:...
Getting code EE 2 on a laser 73 toyostove that runs on kerosene
EE 2 usually has to do with the fuel. Does the heater make a loud ticking or thumping sound? That's the sound the fuel pump makes when its not getting any fuel. Check your filter, check the strainer in the fuel sump. Depending on how cold it is any water in the fuel line could be frozen blocking the fuel flow. You might also check the flame rod for soot. It can be cleaned with some steel wool.(nitensheaterservice@embarqmail.com)
Jan 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
My Toyostove OM-22 smells like exhaust gas in the room. I think its a gasket problem (fuel line looks OK; vent pipe is clean) I want to buy replacement gaskets for the burner, the flame sensor, etc....
There are some orings in the exhaust that might need replacing. Do you have a parts breakdown for the heater? I repair monitor and toyostove heaters and can get you the gaskets. I'm in NC. You can contact me at nitensheaterservice@embarqmail.com
Jan 11, 2010 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 73 EE2
Not having a cleaning in the last couple years may be the problem. Carbon build up in the burner pot and on the flame rod (a chain of carbon) will cause the flame to not be sensed. Then the flame will burn out. A temp solution would be to unplug the stove, then unscrew and jiggle the flame rod to break the chain. When tightening the screws do not over tighten. You could also try hitting the edge of the pot to see if you can knock the carbon loose. You could also have a warped burner ring which would cause problems keeping the stove running.
Nov 03, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
179 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
