Question about Whirlpool Duet GHW9150P Front Load Washer
Water is pouring out were you put the detergent in.
  • Whirlpool Master
  • 8,220 Answers
Remove the top and clean out the fill spout. Remove the dispenser drawer and put it in the dish washer for a good cleaning.
Posted on Jan 01, 2011
When we put the machine on a 90 degree washing cycle water and foam pour out from the detergent drawer
seems as if the water inlet from the detergent drawer to the drum could be clogged up might wanna have it cleaned or replaced
Jan 07, 2017 | Washing Machines
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Wont drain
The wrong type detergent was put in the washer.
Set it to pump out. Then pour in cold water and pump out again. Do this over and over until the suds are gone.
Cold water helps kill the sudsing and dilutes it so it will pump.
Make sure you use dishwasher detergent next time.
Mar 11, 2009 | GE Dishwashers
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Not getting clothes clean
Try using less detergent and putting white vinegar in the rinse water. You can pour 1/4 C. or a little more into the automatic fabric softener dispenser for the final rinse, or put it in by hand.
Nov 23, 2008 | Roper RAS6233KQ Top Load Washer
Water Pouring out of the soap dispenser
ckd the line from dispenser into tub start inside tub first look for clothing caught at inlet point pull dispenser drawer out and ck from dispenser end may try pouring water in from that end also if happen to use dry detergent an undisolved lump may be caught somwhere in between
Nov 08, 2008 | Washing Machines
Detergent in clothes
How much detergent are you using? I'm wondering if there is a residual amount of detergent left in the washer. Does it have a dispenser? If your washer has a dispenser for liquid detergent you could try pouring a small amount of really hot water into the dispenser to ty to clear it. Then try running a small empty cycle or two with plain cold water. Remember not to ever use more detergent than is recommended for your washer.
Thank you for using Fixya.
Aug 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
How to drain liquid chlorine?
Get as much as you can out with a towel, then flush the rest with cold water. Just pour it in and dry it out with a towel until you are able to pour water in it and it go out the dispenser like normal. After you have gotten the dispenser cleaed out you will need to get the detergent out of the machine before using it. Start a cycle with cold water. Let it start washing, when you see suds forming pour in a little vegetable cooking oil. This will kill the suds. Keep doing this through the cycle. After the suds are gone and the cycle is done, run it through another cycle with hot water. If you have no suds you are done. If It still suds up by the end of that cycle, run the cold wash and vegetable oil again.
You should be ok by running one cold and one hot, just watch it and add a little oil to kill the suds.
The cooking oil trick works with dishwashers too if you ever put the wrong detergent in them.
Please reply if you need any more help.
Oct 23, 2007 | Kenmore Oasis 27042 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal De
