Question about Samsung Cell Phones
I cannot for the life of me get the battery cover off. I press down but it won't slide off
Have a look on YouTube - someone's got the answer
Posted on Nov 04, 2008
How can I open the battery door, it is stuck?
Like the manual shows you have to slide the cover and than it will come up.
But if you managed to put the batteries in the wrong way around, or even worse if you let them in for a very long time the door can be blocked by some pressure.
Please press the battery cover down, before you try to open it.
Perhaps you should knock or tap with a finger. Not to much force, but a few taps on the cover. Than again press is down, while sliding outwards. As soon as it moves, careful slide it further till it opens.
May 20, 2014 | Fuji finepix a805 8.3mp 3x digital camera...
Midland walkietalkies -how do you put in new
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Oct 17, 2013 | Midland LXT310 2-Way Radio
My my touch 4g slide won't turn on. when i start it i feel a vibration but screen will not turn on. Help?
Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 11, 2012 | Cell Phones
Water damage
1. Remove the back cover of your phone. To do so, you will have to press down on the silver latch while sliding the cover off toward the top of the phone.
2. Remove the battery from inside of the phone. Be sure to place it somewhere where it will not be damaged. Locate a silver hatch; this is where the SIM card is stored.
3. To undo the silver hatch, slide it in the direction that says "Unlock." Then, flip it upwards so that only one end of it remains attached to the BlackBerry. Carefully remove the SIM card.
4. Replace the SIM card after a few seconds. It should fit back into its place in the exact same way you found it. Lock the silver hatch by laying it back down over the SIM card, and then sliding it the opposite way you had unlocked it before (to the side that says "Lock"). Put the battery back in as well (by fitting one end at a time). Replace the cover (make sure the silver button latches).
5. Turn the phone back on. The "SIM Card Error" message should be gone.
Aug 17, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
Can you please advise me on removing the back to fit my new sim card Regards
To remove the battery and/or cover from the phone, follow the steps and diagrams below:
To remove the cover, lift up (1) press and slide the section of the phone upward.
Installing the SIM card, make sure the gold contacts of the SIM card are facing down before attempting the insertion. Slide the SIM card into the SIM card socket.
Note: The data stored on the SIM card can be damaged if the card is sctrached or bent during installation, so be very careful when installing the SIM card.
Slide the battery into the compartment so that the tabs on the end align with the slots at the bottom of the device and the metal contacts line up with the those on the device. Lightly press down on the battery until it slips into place
Lastly, Place the battery cover onto the back of the phone (the tabs at the top of the battery cover should interlock in the body chassis). Lower the battery cover down until it is flush with the phone.
Thanks.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
C annot get batteries in amw47eu mouse
Remove the battery cover from the back of the mouse by sliding off the cover of the mouse. Hold the mouse in your hands and with the back of the mouse away from you. Press down on the corners of the battery cover and slide towards the back of the mouse. Lift the cover off from the back of the mouse.
Mar 28, 2011 | Computers & Internet
How do i replace the batteries in this device?
To install the batteries:1. With the back of the radio facing you, remove the belt clip (seediagram below) for easy access, then remove the Battery Coverby pressing down on the top center and sliding it down from theradio.2. Insert 4 AA batteries observing the polarity as shown. Installingthe batteries incorrectly will prevent the unit from operating ormay damage the unit.3. Return the Battery Cover by sliding it up on the radio. Replace thebelt clip, making sure it locks into place.
To install the batteries: 1. With the back of the radio facing you, remove the belt clip (see diagram below) for easy access, then remove the Battery Cover by pressing down on the top center and sliding it down from the radio. 2. Insert 4 AA batteries observing the polarity as shown. Installing the batteries incorrectly will prevent the unit from operating or may damage the unit. 3. Return the Battery Cover by sliding it up on the radio. Replace the belt clip, making sure it locks into place.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Midland LXT310 2-Way Radio
I don,t know how battery cover opens so i can install the batterys,
The battery cover is the bulged part of the plastic, on mine it's a gray color compared to the black body. with the LCD screen to the left and the gray cover to the right, gently press down on the part of the battery cover nearest the LCD screen and press to the right.
That should open it up and get you to the batteries.
Mar 05, 2011 | VuPoint PDSST410VP
My battery wont charge and i can't get the cover the battery off. how do I get it off?
To get the direction to take off the back cover of the phone depends on the type of the phone you are trying to get the back cover off. But for all phones, it is either you press down the back cover then slide it down as you press it down.
Another way is that there used to be a hook by the top of the back cover, press it down and gently slide down the back cover. Or you look around the back cover to see where it is being hooked so you release it from there and lift off the back cover.
If this does not help, please state the exact type of motorola phone you are trying to get the back cover off. Also, try out the charger on another phone to see if the fault is not from the charger.
Hope this helps.
Dec 22, 2010 | Motorola Cell Phones
How can i remove the battery from my lg xenon?
Hello.
To remove the battery cover, press down on the notch at the bottom of the phone and slide the cover. The battery cover should slide and lift off easily.
Hold the top edge of the battery and using your fingernail, lift the battery from the battery compartment.
Hope this helps.
Jan 14, 2010 | LG Xenon GR500 Cell Phone
Cell Phones Logo
82 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
