Question about Garden
My auger stops rotating with heavy snow loads. It sounds as tho a clutch is slipping. I tried to tighten up on the spring in the control cable, but that did not help.What do I adjust next?
    Novelist:
  • 171 Answers
The most common cause of this is the drive belt is worn. If you remove the cover in the middle of the snow thrower and look at the belt farthest from the motor. This is the auger/blower drive belt.
With the engine not running, have someone depress the auger lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
I didn't see what make and model this blower was but:
If this is a craftsman you can get parts through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
Feb 03, 2015 | Ariens Garden
Auger won't stop
Open up plastic cover over belts.There is a pulley that moves against belt to engage front auger.There is a spring that hold it in the off position and when you pull the handle it moves that pulley.Sounds like spring broke or slipped off.
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
How to adjust a 9460897 mtd snow blower auger clutch cable.
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Feb 15, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Hi, i have a 20 inch 12 amp yard works snow thrower. the problem i now have is under heavy load of snow, the impeler stops turning, but the electric moter keeps running. under a lite load it works as it...
Does the impeller have a clutch control so that the motor continues to run, but the impeller/auger stops? If so, then clutch travel adjustment should fix the problem. If there are no obvious adjustments to a clutch-less drive, then shifting the motor position should tighten the belt. If the motor position is fixed, then replacement of the belt seems to be the only option. Wear at the sides of the belt can cause slippage. Hope this helps!
Jan 09, 2011 | Garden
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
The spring on my auger clutch cable broke. Where does this spring connect too? I ordered a new cable and spring but I can't locate where the spring connects too. I have a model 317-611D000 snowblower
my auger cable is not working the auger so i adjusted it and it was to tight and the plastic holder that holds the cables poped off and broke,now the cable i adjust it and nothing happens,cable is all hooked up and seems ok but it will not work right,but the auger spins with out the cable,wondering if it needs a new auger cable
Dec 26, 2010 | Mtd Genuine 9460897 Snow Blower Auger...
Craftsman snowthrower will not throw snow
I have the same machine and it sounds like the belt is indeed slipping.  If the belt is not worn or stretched too badly, you can perform a small adjustment on the idler-wheel (the thing that controls belt tension) by sliding back the plastic cover on the spring that is attached to the bottom of the lever-cable and tightening the nut so that there is less slack in the cable.  If the nut is all already all the up, then you need to replace the belt, which can be easily accessed by removing the plastic cover in front of the motor under where the spare shear pin compartment is located.  There are two bolts (one on each side) that need to be removed and then the cover just pulls off.  This will expose both belts.  The front one is for the auger drive and the rear one is for the wheel drive.  The belt can be easily replaced without any further dis-assembly by simply removing and replacing it in the reverse manner.  Don't forget to readjust the spring so that excessive tension is not applied to the new belt.  Hope this helps.
Jan 10, 2009 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
198 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
