Question about GE WSXH208A Front Load Washer
The seal has a nick in the front and water leaks...can we turn the seal so the nick is at the top?
  • 312 Answers
I personally would be tempted to turn the seal around. However the nick in the front may or may not be the actual problem. Also the seal may be more delicate that you think and could tear in the process of rotating it. Since it is an expensive replacement part I would very carefully examine the seal with an excellent flash light to see if there are any pin holes in the lower folds as well as that nick.
Also look at the links below.
Hope this helps,
Happy New Year
Mark
http://www.fixya.com/support/t5789753-front_load_ge_washer_model_gcvh6260f
http://www.fixya.com/support/t3835614-water_leaking_needs_new_seal
http://www.fixya.com/support/t2785878-ge_adora_making_clothes_stink_like
Posted on Jan 01, 2011
How do you remove the cover of a Kenmore elite top load washer . Have a leak and need to find where it is coming from.
water coming from the bad seal on the shaft. Lift agitator, bolt underneath, loosen pull out basket. From spindle. ..seal underneath. Must take cover off first. Slide a butter knife at edges in front at seam. there's a two ,clips. in there. Usually 2 bolts up towards top on inside edge of front cover. Make sure power cord unplugged.turn basket upside down. You will see seal.
Sep 11, 2014 | Kenmore 24032\24036 Top Load Washer
Water is coming out of top washing machine.The wateris not overflowing.It looks like I see lintclogged at the top of the drum'How do i take the top off to clean it.I have a whirlpool model LSR5132the last...
Ignore the lint, it wont cause a leak. The shiny wash drum gets wet, so it sits in a sealed outer drum that contains the water. The water can only get out of it at the front where their is a rubber seal around the door, or through broken bearings at the back. Is the water coming out at top front or top back? Front seal fix is easy, but changing rear bearings takes me 4 hours.
Dec 14, 2013 | Washing Machines
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Stoves dishwasher leaking from the door
Check the latch at the top, this can be adjusted to seat the door better against the seal, another couple of places they can leak is around the powder dispenser in the door and also check the door seal for nicks or splits.
Mar 10, 2012 | Stoves 27 in. DW60 Built-in Dishwasher
Leaking water
When your Maytag top load washing machine leaks water, you will need to check the following parts until you find where the leak is coming from.
The water valve: The first place you need to check is behind the washer. Check the two fill hoses and the water mixing valve.
Check for pinholes or cracks on the plastic body of water mixing valve.
Remove the front panel : The next thing you need to do, is to remove the front panel so you could see the tub and the hoses.
Set the washer on the regular cycle and turn it on so it could start filling.
Use a drop light and check all the hoses under the washer as the washer is filling.
Make sure to keep your hands away from any moving parts.
The pump : If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag washing machine to leak water.
The stem & seal : Another place that the washer could leak water from, is the stem & seal on the holding tank.
When washer leaks water from the stem & seal, the water will leak down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110.
Apr 19, 2010 | Maytag PAV2300 Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
WATER LEAK WHEN FILLING
IS your leak in the front or the back? front could be the pump seal is broke and back would be you water inlet valves. Pump tilt it back and look underneath for leaky seal and water inlet valves you need to take the back off this is a tricky but doable process. post model numbers from now on please
Mar 09, 2009 | Roper RAS8445KQ Top Load Washer
Yamaha WR250F Leaking coolant
yes thats the weep hole it leaks when your water pump iner seal starts going bad,
Nov 27, 2008 | 2005 Yamaha WR 250 F
GE WSXH208A Front Load Washer Logo
43 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
