Question about Brother MFC-260C All-In-One InkJet Printer
Cyan is not printing after cleaning ROS on Docucolor 260
    President:
  • 2,047 Answers
Printers are very sensitive when it comes to printing ink. Your printer refusing to print the cyan color comes as a result of various things it could be as a result of blocked nozzles or low ink in the cyan ink. Check the ink level in the cyan ink cartridge if it is low then the ink needs to be replaced.
If on the other hand the printer still does not print cyan then the nozzles which supply the cyan colour are blocked and needs to be serviced or replaced.
Hope this solution has been helpful?
Happy new year.
Posted on Jan 01, 2011
I have fadded line on my cyan tone prints
open cyne devloper module and clean devloper by teaspoon
Jan 23, 2013 | Xerox DocuColor 240 242 250 252 260 ROS...
Xerox docucolor 1632 fault code: 004-341 the printer doesn't print at all
Try reseating the waste toner then all 4 drums, see if the chips are mating.
Most likely either the machine software is corrupted and needs to be reloaded, or the MCU board has failed, could also be a bad laser, called the ROS.
Jan 02, 2010 | Xerox DocuColor 1632 Laser Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
Brother MFC-260C All-In-One InkJet Printer Logo
196 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
