Question about Kenmore 15516 Mechanical Sewing Machine
I dont know what Kenmore model I have it is older. Now the needle will not go up & down all the way and is stuck in my material?
    Genius:
  • 1,788 Answers
You have to wiggle the handwheel back a forth to free the fabric. See if you cannot remove your needle completely, even if you have to cut it, then pull all of the pieces out. Now, clean and lubricate the machine, another little thing, unscrew the throat plate with a short stubby screwdriver, there is usually a nest of felt like lint collected there. Remove it. totally rethread. Do not turn your handwheel away from you because you will mess up your timing and have to take it for service, it is not a do it yourself job. The next time you sew, make sure you hold your uppper and lower threads for a few stitches. Use a stabilizer of some sort, you can usually use gift tissue paper or printer paper until you get going. Be patient and you will get it. Good luck Happy New Year
Posted on Jan 01, 2011
My needle will not go up and down
hi Tamara.
you have not said the make or model.but try this.
Make sure the push your bobbin winder to the right then to the left and see if that solves the problem. Your Old Machine has a Clutch & It Needs to be Released. The Clutch is this little dial that is inside of the hand wheel. In older machines, it was used to wind the bobbin without the needle going up and down.17 Jul 2015
My Needle is Stuck! My Hand Wheel Won't Move ... - It's Just Sewing
you could also go to this link and see if it helps.when you go to this link if a small windows open in the middle just close that little window.
My Needle is Stuck My Hand Wheel Won Move HELP It Just Sewing
Nov 20, 2017 | Sewing Machines
I was trying to feed bobbin thread and the needle is stuck. It will not go up or down. I took the bobbin out and it still will not go.
Is there any thread or other items stuck in the bobbin case or wound around the needle tip causing it to stick?
Jan 07, 2017 | Sewing Machines
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
Brother cs 5000h is totally jammed, hand crank won't turn, needle stuck in down position
I would totally remove the bobbin apparatus & check that area
Oct 09, 2017 | Sewing Machines
The machine is eating my material
try changing thread top & bobbin
make sure the bobbin area is clean of lint & loose thread
make sure there is no lint in the feed dog area
change the needle
make sure the thread stay on the thread take up lever
sometimes needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
if none of these suggestions work then the machine may be out of time & needs to be repaired
Nov 02, 2010 | Kenmore Sewing Machines
Thread knots up on bottom of material and won't sew and gets stuck needle will not move up or down
try a new needle & check to see if the thread has come off the thread take up lever,, that will make the machine jam up
Oct 26, 2010 | Singer Sewing Machines
I don't know what kind of needles to use. I have three older machines (117.552 158.18030 158.13201) all bought used. The manuals all say use Kenmore needles -not enough info. Is the 15x1 series of needle...
You can use Kenmore, Singer, Klasse, Schmetz or Organ needles for home sewing machines - they are the same configuration.
The instruction manual should indicate how to insert the needle, either according to the flat side of the needle shaft or the groove down the front of the needle.
Needles for older machines may require a round shaft needle. Needles for industrial sewing machines have a round shaft.
May 18, 2010 | Sewing Machines
Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Dec 30, 2009 | PfaFF Sewing Machines
My material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Oct 17, 2009 | Sewing Machines
Can these needles be used with my sewing machine?
Don't know if this is helpful...but I have a very old Kenmore and 2 Brothers. I used the same needles with all 3 machines. No problems.
Apr 13, 2009 | Sewing Machines
Kenmore 15516 Mechanical Sewing Machine Logo
35 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
