Question about Canon imageRUNNER 2200
I am getting a one-inch gray stripe at the top of each copy, and a half-inch stripe at the bottom of each. I think I've cleaned everything ... platen, narrow glass, rollers, etc. ... and it's lightened, but not disappeared. What's next? More of the same, or something else. Can't find the corona wire. Canon Imagerunner 2200
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Change your dram and dc blade.
Posted on Apr 28, 2016
  • Canon Expert
  • 122 Answers
There is no corona wire but a primary charging roller pls clean it if both ends of the roller looks rough or cracky try replacing it and clean transfer roller as well.
Posted on Jan 05, 2011
Gray vertical bars on screen but no picture
It sounds like you might have shorted out the display panel driver board / boards.
These boards are located at the bottom of the screen and are prone to liquid damage.
Just before this happened, did you happen to spill something on the screen or clean the screen using a spray bottle cleaner?
The only fix I know of is to replace the whole panel but it is usually just as cheap to buy a new TV.
Nov 28, 2013 | LG 55LE5400 55-Inch 1080p 120 Hz LED HDTV...
When I fax or copy I get a gray line down the right side of the paper from top to bottom. It is about a inch or so from the side.I have a MFC6490CW. Thank you
Check your scanner bar for dirt or "Whiteout" residue. You can clean it with alcohol and test your results by using the "copy" function.
Nov 08, 2010 | Brother Office Equipment & Supplies
My ir 400 gives a white spot
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Jun 16, 2010 | Canon imageRUNNER 400S Copier
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Prints B&W in Horizontal Stripes
I received an answer elsewhere. Thank you.
Jan 26, 2010 | Canon Office Equipment & Supplies
GRAY STRIPES ON COPIES
clean the glass. it must have streaks
May 28, 2009 | Canon imageRUNNER 210S Copier
Gray continuous streaks on lower half of copy using Canon IR 1600
I assume you had the issue before you changed the toner, If so the problem is either the fuser or the Laser.
Do this:
start a print job and after you hear the paper feed into the machine open the top cover to stop the machine. You want to stop the page before it gets to the fuser. May take a couple tries.
remove the toner cart.
the page should be under the cart with the image on it.
If the line is on the page the problem is image development(toner or laser).
If no lines the problem is likely the fusing assm.
May 28, 2009 | HP LaserJet 8100N Printer - Refurbished
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Minolta Copy Machine
hello sir; You need to replace drum cleaning blade or drum cartridge will be take care of your problem.
Jan 29, 2009 | Minolta EP1083 CS/PRO Copier
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon imageRUNNER 2200 Logo
173 people viewed this question
old marine
old marine
