Question about Royal Health & Beauty
My Royal Tel-Weight talking scale seems to be weighing about 50 pounds less than it should. Now that my husband knows how much it is off I need to get it fixed, if possible. Thank you , Marcie Chiarello
  • 1 more comment
  • mchiarello Jan 04, 2011
    No, there is no place underneath to adjust the weight.
  • mchiarello Jan 06, 2011
    No there is no way to manually adjust the weight.
    There is no way to adjust the weight.
  • 22,326 Answers
Is their some sort of adjustment underneath to set it correct ,put a test weight on and then adjust it to read true ??
Posted on Jan 01, 2011
2002FOREST RIVER WILDWOOD T25
You can take it to a truck scale to have it weighed. Your owners manual will give the trailer weight before you loaded it with camping equipment and kitchen ware. It weighs more than "off the showroom" floor weight....I'll bet. Good Luck....fill the holding tanks ...then go weigh, or look up capacity of your holding tanks and then multiply the gallon amounts X the weight of one gallon of water. Which is 8.35 pounds. And gasoline is 5.8 - 6.3 pounds. diesel = 7.15 pounds. Propane = about 4.11 pounds.
Mar 10, 2015 | RVs
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
My scale adds anywhere from 5 lbs to 35 lbs to my family's weight. I just had my daughter weighed yesterday and this scale added 5 lbs and when my husband or I get on it, it adds anywhere from 30 to 35 lbs...
there should be a dial on the sides to zero it out. if it doesnt, then it has something to do on the actual scale. does it have a menu or settings option? you should be able to zero it out.
Dec 10, 2010 | Homedics Glass Digital Scale - Advanced...
The weight jumps around. If I get off the scale and on again, the weight changes by 5 pounds. I am sure neither weight is correct.
You're only suppose to weigh yourself once a week. Make sure you're doing it after you've gone to the bathroom in the morning and with no clothes on. Other than that, I'd make sure the floor you set the scale on is level and that you are holding very still while weighing.
Feb 28, 2010 | Conair WW60 Weightwatchers Scale
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Health & Beauty Logo
118 people viewed this question
Top Royal Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Royal Health and Beauty Expert? Answer questions, earn points and help others
