Manual for hec 1050w washing machine - Washing Machines
SOURCE: Lost washing instructions for HEC
turn small left dial to 40.
Then turn right dial to the wash you desire:
(cotton)1. intense 2.prewash 3.normal 4.middle 5.delicate
(synthetic)6.normal 7.middle 8.delicate
(wool)9. normal 10. delicate
(silk) 11.normal 12.delicate
13 quick 14 rinse 15 spin 0 end
hope this helps
Posted on Jan 05, 2010
SOURCE: lost manual for HEC 1050w washing machine. Not sure which compartment i use for powder conditioner. Think i've been using wrong one!
turn the dial to zero, turn it off. it does this at the end ofa cycle and until you set it to zero it will flash when you turn it on.
Posted on Jan 21, 2010
  • 58 Answers
SOURCE: where can i get manual for HEC washing machine
http://www.haier.com/products/product.asp?proID=10580
Posted on Mar 09, 2010
rickyrt441
  • 4399 Answers
SOURCE: My HEC 1050w washing machine
Thanks for choosing FixYa and welcome to the site. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 07, 2011
SOURCE: where can i get a user manual for HEC 1050w
http://www.haier.net/admin/en/product/upload/HEC1050W-UM.pdf
Posted on Jun 05, 2011
Is it possible to print off the instruction manual for the HEC 1050W washing machine
Hi Geoffrey,
  1. Here is how to do it. Click on this link and download & save it to your PC.
  2. Then open it, you can choose which page you want to print.
Best of Luck
JP
Haier HEC1050S User Manual
Jun 25, 2015 | Washing Machines
Hec 1050w
oh hec its a hec
have you cleaned the filter
Feb 03, 2014 | Washing Machines
Where can i get a user manual for HEC 1050w washing machine from?
Apr 16, 2011 | Washing Machines
Manual for HEC washing machine model 1005A
i have hec 1005 washing machine how can i take dispenser drawer out
Oct 09, 2010 | Washing Machines
Not allowing water in, and not rinsing.....it is hec 1050w
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 17, 2010 | Washing Machines
Washing Machines Logo
361 people viewed this question
Top Washing Machines Experts
