Question about Amana DRSE663B Side by Side Refrigerator
Freezer has frost in the back wall and ice is not being made
  • Amana Master
  • 8,220 Answers
You either have a broken defrost heater or defrost termination thermostat. Frost on the back wall is a dead give away. Remove that service pane and you will likely see a big old mess of ice blocking the air and reducing the efficiency of this machine. Here is your Amana Service manual for bottom mount ice box Freezer has frost in the - themobilian_647.jpg
Posted on Jan 01, 2011
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
4 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Posted on Aug 28, 2007
sdmc73
  • 121 Answers
SOURCE: warm fridge
check the fan in the frezer and check the defrost
Posted on Nov 29, 2008
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
Back wall ice buildup, fridge not cooling but freezer is fine other than ice. Back wall of refrigerator squishes with sound of water behind it. Have had it unplugged for 24 hours, ice gone.
Anytime you have ice buildup in back of freezer it indicates that the auto defrost mechanism is not working. Check the defrost timer, heater element, defrost thermostat for proper operation.
Jul 19, 2015 | GE Profile 24.7 cu. ft. Top Freezer...
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My freezer keeps frosting up
if on the back wall of unit you have a defrost issue recommend replaceing the adc/timer and defrost thermast. if not on the back wall you have a air leak often found around the doors and the ice chute .more often the ice shut look to see if everything is closing tight
Jun 03, 2010 | KitchenAid (KSRD22FKST) Side by Side...
The fridge compartment does not coolbut freezer is ok in my no frost model, there appear to be problem in getting cold freezer air into fridge area
look in the back of freezer . if there is ice or frost on back wall . then your coil is ice packed .. this is caused by the failure of defrost system . when ice is blocking coil the air that goes to the fresh food side doesn't get there. ..
Dec 09, 2009 | Refrigerators
The freezer is well and very cold, but the refrigerator is cool ,but not cold enough to keep the food well.
Check and see if there is frost on the back wall of the freezer. Also make sure the fan is running in the freezer. If the fan isn't running in the freezer replace it. If you have any frost or ice on the back wall of the freezer, remove the back wall inside the freezer. Check and see if the coils are completely frosted over. Thaw the coils out with a hair dryer, then measure the heater and make sure it measure there. (ohms)
If it's ok, then the defrost thermostat which is attached to the coils or the defrost timer is bad.
Sep 15, 2009 | Refrigerators
Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
If the frost is on the back wall of the freezer then you most likely have a defrost problem or a bad evaporator fan motor.
Jan 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Frig not cold but freezer is ice maker not making much ice either
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Amana DRSE663B Side by Side Refrigerator Logo
147 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
