Question about Panasonic DMR-E55 DVD Recorder
Unable to record channel 4 5 and other channels I;m using the timer recorder and I get L1, L2 L3
  • 441 Answers
You are on the wrong input, the input should give you a channel number. You need to run the auto channel scan before it will go to the channels
Posted on Jan 04, 2011
Sony dvd/video recorder turns on, says L2 then cuts off..what's the problem
Hit the input select on either your remote or behind the flap on the front of the unit. It might be turned off cause nothings plugged in to the L2 channel. I believe you should have an L1, L2 and L3 channel. I'm almost positive L2 is an auxiliary channel and not an error code but u could be wrong
Nov 05, 2014 | Televison & Video
Can't get rid off L2 message on the recorder.
If I'm understanding this as what I think it is - that's not an error message at all! It's the input your recorder is currently set on (I'm talking about the "L2" shown in the right side of the LED display when the unit is powered on, where the channel number would usually be.) In order to change that, you have to open the bottom flap on the front of the machine (or slide open the remote bottom for the record controls to be exposed,) and press the "Input Select" button twice until it cycles through L3 and ends on whatever channel you last left it on - I think it defaults to 100 if the power has been interrupted. When you press this button after that, it would cycle through "L1", "L2", "L3", and the channel input (or coaxial cable input, to be exact), as expected. I know of no other "L2" message you might be speaking of. If I'm incorrect on this, I apologize. But I hope I'm not and that this simple issue is all that is causing you a headache! Good luck! And by the way, "L1,2, & 3" are the RCA/S-Video inputs on the back (L1 and L3) and on the front (L2) of your machine for various things you might plug in (video cameras, etc.) Note: For L1 and L3 ONLY, you have to go into setup to select whether you will be using the RCA yellow or S-Video jack on the back of the machine for the video of that particular input (with no bearing on the RCA audio jacks for that particular input - they're always used...) - the front L2 input evidently selects on its own between S-Video and the RCA yellow plug, based on which plug has something plugged in. I haven't tested to see which it will select if they are both occupied with a plug on L2. I don't mean to treat you like an idiot -- please don't take it that way - but I don't know how much you know about electronics, and IF I'm right about this whole thing, then I'm sort of assuming you aren't too familiar with them. In either case, please know that I mean well, and any information that you already know, just overlook. Thanks, and again, good luck!
May 29, 2011 | Sony RDR-GX300 DVD Recorder
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
Panasonic PV-9451 VCR, When setting up the VCR to record a channel, the only channel options are Channel 02 thru 25 and L1 And L2. What has to be reset with the digital cable input??
You will need to use L1 or L2 (one is probably on the front of the VCR, and the other on the back, they should be labeled).
YOu need to plug the digital receiver's output into L1, or L2, and set the VCR to record the one you're using. Then set it to the time you want, and then set the channel on the digital box tho the one you want.
One Channel, One time. (or recurring daily, if your VCR allows daily recording from L1,2)
Jun 13, 2009 | Televison & Video
How do I record a TV Program.
Video & Left,Right audio go out of Comcast cable box to L1 input on DVD recorder,Video & Left,Right audio go out of DVD recorder to a line input of your TV.  Record L1 input on DVD recorder.
Jan 10, 2009 | Panasonic DMR-E80H DVD Recorder
How to program vcr using L1L2
I think that L1 and L2 are the extension inputs (scart/phono) from an external source therfor you will only be able to record whatever channel they are on. to make a timed recording you will have to input time date channel you will be unable to record via videoplus.
SUPER8
Nov 14, 2008 | Sony SLV-D350P DVD Player/VCR
Channel selection
L1 and L2 are just line inputs. This unit does not have a tuner so there are no channels to select.
It requires you to be connected to a TV broadcast via a cable or satellite tuner box... and then would only record what ever channel you were viewing. The DVD is a player only.
It sounds like you should have purchased a DVD Recorder or a DVD/VCR Recorder. The players normally do not have a tuner. A Recorder should have an built-in digital tuner. Some also have the old NTSC tuner and may also have a QAM tuner.
Nov 12, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot do timer recording
I need more information, what kind of recorder is? it has built in tv tuner?
Nov 11, 2008 | Philips Magnavox DVD/VCR Dual Player
Channel setup for VCR recording
WHAT YOU HAVE TO DO IS GO INTO SETUP AND DO A 'CHANNEL SET' EITHER AUTOMATIC (WHICH DID NOT WORK ON MINE) OR MANUAL AND ENTER EACH AND EVERY CHANNEL YOU WANT TO RECORD. THIS IS TIME CONSUMING BUT THAT IS THE ONLY WAY IT WILL WORK - IF YOURS WORKS WITH 'AUTOMATIC' YOU GOT IT MADE
Jan 24, 2008 | Philips Magnavox DVD/VCR Dual Player
No sound when recording channel 3
Is this when you are recording via CH 3 from a separate source? If so, try CH 4 or alternately, L1, L2 inputs.
Nov 13, 2007 | Panasonic PV-V4523S VHS VCR
Panasonic DMR-E55 DVD Recorder Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
