Question about Qwestar Car Audio & Video
I have a Qwestar 6 disc cd changer Modle KCD-003A and just wondering if it would fit in a Ford Taurus SEL Modle - year 2002
  • 883 Answers
SOURCE: Qwestar 10 Disc Cd Changer
have you tried the qwestar website?
Posted on May 25, 2007
SOURCE: My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Posted on Jun 28, 2008
SOURCE: cd eject error
I've read that you can disconnect the battery and reset the unit. It might be worth a try.
Posted on Sep 14, 2008
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Posted on Jun 15, 2009
SOURCE: ford factory in dash 6 disc changer/radio
I have had the same problem with my Ford CD player, if you unhook the battery and let the entire system reset itself for approximately 10 min. or so and then rehook the battery and the CD that is stuck will either come out automatically or when you push eject. If you have not let the system off the battery long enough it does not work. Trust me I have had to do this more times than I can count.
Posted on Dec 07, 2009
2007 ford taurus air bag light on after replacing stereo
The CD changer option is similar to the single-disc player. The CD changer has the ability to toggle between the stereo and the multi-disc changer. In the 2007 Ford Taurus, the CD changer is located either in the vehicle's trunk or in the center console and has a magazine that can hold up to six CDs.---------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
Why is my 6 disc cd changer in my 2007 ford fusion not working? it just says error. What should I do? Thanks!
Its possible that recently disconnected the battery and the LOCK CODE needed re-enter.
Check your owners manual to the procedure.
Good luck.
Jul 14, 2010 | 2007 Ford Fusion I4 SEL Sedan
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
1999 Ford SE digital display reads ''NO CD'' and changer is stuck
Magazine-type CD changers are prone to jamming with a disc in transit between the magazine and the player. You may have to resort to disassembling the trunk unit to get access to the jam.
Apr 15, 2017 | 1999 Ford Taurus
97 ford escort 6 disc changer
check for something maybe jammed in the system and also try a cleaner disc to see if this helps the eye to read the disc and is this an after market changer or a standard accessory on the car when bought and if it is an aftermarket check to make sure it is hooked up correctly
Dec 26, 2008 | 2004 Ford Taurus
6 disc cd changer skipping
Laser is loose or out of alignment return to factory for adjustment.RICHARDM69
Dec 14, 2008 | Pyle PLCDCHK6 6-Disc CD Changer
2003 ford taurus
check the fuse 1st, but chances are the changer is defective and will have to sent out, these changers are really prone to this problem. Even if the fuse is blown what made it blow? most likely a short in the changer.
Nov 06, 2008 | 2003 Ford Taurus
QWESTAR 10 DISC CD CHANGER WITH FM MODULATOR
connect the 12V IGN to the switched supply from the ignition and Back up to the unswitched supply straight from battery.
Jan 09, 2008 | Qwestar QC280 10-Disc CD Changer
May 25, 2007 | Qwestar QC280 10-Disc CD Changer
Car Audio & Video Logo
103 people viewed this question
Top Qwestar Car Audio & Video Experts
xxxxxx xxx
Are you a Qwestar Car Audio and Video Expert? Answer questions, earn points and help others
