Question about Amana ASD2620HRZ Side by Side Refrigerator
Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 01, 2011
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
How can I tell if my fridge isn't working?
Unplug the Ref for 15-20 min. take off the cover so you can see the compressor, then plug it back in and listen for the compressor to start. You should be behind the Ref so you can tell the difference between the fan running or the compressor.
The compressor should start and keep running.
The fan cooling the compressor should be running.
The fan in the freezer should be running.
You should feel cold air coming into the Fridge side from the freezer side.
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator is not cooling
hi thanks for the question you say the fridge is still running is the fan in the freezer running at the back is the compressor running if the compressor is not running and is very hot it could be a bad compressor is there a fan down by the compressor if there is a fan by the compressor is it going if not replace the fanthanks the appliance doc
Aug 14, 2008 | Whirlpool ED2FHEXN Side by Side...
Cold temps
Same thing happened to us. A baffle that conducts air from the freezer to the fridge gets stuck in the "open" position and needs to be replaced. That'll fix that problem but watch for others including the water dispenser that spontaneously begins blasting water across your floor. We've dealt with this twice.
Jun 08, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Neither Freezer nor refrig is cooling
Pull the compressor side cover off. Pry off the square box. This is your compressor start relay. Check for continuity. It's probably blown. If ok check for voltage to the compressor.
Jun 07, 2007 | Amana ASD 2624 Side by Side Refrigerator
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Freezer works, fan works, fridge side not getting cold
Whip, make sure the condensor fan is running in back. It should be running anytime the compressor is running. Check to see if you have a buildup of frost on the back of the freezer panel, this could indicate a defrost issue. This refer is controlled by one main mother board in back. Check these things first and post back. You may have to do some tests on the board...Catriver..post back.
Nov 24, 2006 | GE GSS25JEM Side by Side Refrigerator
Refrigerators Logo
115 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
