Question about Hitachi 51SWX20B 51" Rear Projection Television
Last night we got some multicolor, green, yellow etc horizontal, kind of half moon shapes coming across the screen, removed the front screen and cleaned the lens's and mirror,, no change. Any Ideas? Thanks, Tom Guy tv model is Hitachi 51SWX20B
  • Hitachi Master
  • 3,459 Answers
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid changLast night we got some - 65af323.jpg/>65aLast night we got some - 69189a5.pnglass=
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jan 13, 2011
Fixing Bizhub c350 LCC ascent motion failure (soft limit error)
Take front cover off of the LCC. Then remove the two gears with the special marks on them align marks. On the shaft that raises the paper is a black gear that last one have seen that get completely round out instead of the half moon shape it is suppose to have. so it slips and no paper gets raised
Aug 28, 2014 | Konica Minolta bizhub Office Equipment &...
How to adjust bobbin tension bernina 150
On the side of the bobbin case is a half moon shaped curved spring with a screw through it securing it to the bobbin case
take the small yellow or red screwdriver that came with your machine and turn the screw clock wise to tighten and counter clockwise to loosen. Correct tension is achieved by inserting a full bobbin of thread, into bobbin case, remove the half moon shaped shuttle from machine, put the bobbin case on to the shuttle, now hold just thread and with a youo motion shake the above and the shuttle and bobbin case should slide down the thread about 12 to 24 inches for correct tension
Jul 09, 2014 | Bernina Virtuosa 150
Hello i have a black line runnig across my screen horizontally. Some times disapperar for a few seconds and tv is normal and then comes back. Some tines is black and some times l flashes in red, ...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELPOUT IN SOLVING THE PROBLEM...
May 18, 2011 | Televison & Video
How do I get my monitor back on if I accidently press the key in the top left corner (with the half-moon shape on it). What is that key for?
That's the sleep button
(half-moon -> night-time -> sleep).
It puts the PC into standby mode. Pressing the power button should bring it back to life.
Apr 10, 2010 | ASUS Laptop Keyboard for Asus A3, A6, A9,...
Replacing camshaft position sensor, Sable 2003,Ohv
usually if the magnet in the sensor comes out it destroys the cam position shaft,(it should have a half moon shape when u remove the sensor from the cam pos/oil pump drive. if the half moon is damaged or missing u must replace the cam pos/oil pump drive, and yes it is timed with the engine. wot i have done is try to locate where the half moon was on the drive it usually leave a trace of where it was. now index where the half moon is at remove hold down bolt and remove the driver assy. install the new drive, clock the half moon shaft to match the one u just removed once u get the half moon shaft where u want it and the oil pump rod alines and the whole housing is down install the hold down clamp. now to get rid if that check engine lite youll have to plug a scanner in and look at the live data adjust the cam position till u have plus or minus 2 degrees
Mar 18, 2010 | 2003 Mercury Sable
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Hitachi 51SWX20B 51" Rear Projection Television Logo
110 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
