Question about Garden
I have an MHT products inc model 500 heat gun. I took this apart to fix it a long time ago. Need a diagram to determine where the wires go on the switch. I only get cold air now
ginko
  • 19396 Answers
SOURCE: ASSEMBLY
Check this link here it is not a diagram but there is a view of the disassembled tool, and some instructions.
Posted on Sep 04, 2008
  • 71 Answers
SOURCE: I need a wiring diagram for a 1999 Jeep Grand Cherokee
Here is the stereo wires which may help you figure out which are not the ac wires etc. hope this helps with some of the problem.
Constant 12V+ Red/White  Switched 12V+ White/Red  Ground Black  Illumination n/a  Dimmer Orange  Antenna Right Front  Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red  Left Front (-) Light Green/Green  Right Front (+) Light Blue/Red  Right Front (-) Light Blue/Black  Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White  Left Rear (-) White/Dark Green  Right Rear (+) White/Purple  Right Rear (-) Tan/Dark Green
Posted on Nov 27, 2008
SOURCE: Reassembly of Air Rifle
Go to www.airgundevelopment.com and scroll down to the link that says crossman valve. I used these pictures to get mine back together. It's not an exact science, but it sure does help.
Posted on Mar 05, 2009
  • 23 Answers
SOURCE: heat pump Bryant model 541DJ024 Is there a reset
their is sometimes a high psi switch that has a manual reset. it is red with a red rubber button. it is usualy lokated in th outdoor unit. in most areas it is code that their is a disconnect within 10 ft of the unit most of the time they have fuses in them. open the disconnect and their is a plastic sheild that needs removed sometimes.
Posted on Jun 15, 2009
cactus bob
  • 267 Answers
SOURCE: button to toast won't latch
THE BOARD IS BAD .the problem is b&d will not sell it to you . i had one that i DID FIX , there was a problem in the power supply on the board , i checked out the parts i needed there where 2 diodes , and an scr transistor i found bad . ordered them (with shipping 28.00 ) got them and installed . and the first power up POP the ic timer blew apart and damaged the two diodes . cost of the ic another 25.00 plus the other parts. so i now have around 60.00 in parts and 4 hours labor in to my great working 7 year old toaster oven ( that i only paid 25.00 for in the first place ) so unless your like me and never give up ,NO MATTER WHAT ! its time for a new toaster oven ......... if this answer helped please rate a 3 or 4 stars this high rateing will help keep me in the paid answer department , thank you
Posted on Jun 21, 2009
I need a wiring diagram for the trigger mechanism for a POWER-CRAFT soldering gun model 84 TWL 6091A.
You need this part: Weller 7324 Switch for Dual Heat Model 8200, D550 and D650 Soldering Guns That will repair the unit. Wire diagram is inconsequential .
May 18, 2016 | Welding Tools
I have the older jl 500/1 its black and i believe i didnt have a large enough power wire and i took it apart and the only thing i observed was the 12v input terminal had gotten hot and kind of made its way...
The best advice i can offer is to take it to a JL technician and have the amplifier professionally repaired. The amplifier you have is a very good amplifier, so having it repaired by a professional, is worth it. After you repair it, make sure to run a 4 Gauge cable to the amplifier this time around.
dreamsystems
Feb 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
Graco Mirage Pram - need a manual to put together after washing.
Graco Children's Products Inc.
Product Instructions
LINK: http://www.gracobaby.com/customerservice/instructions.aspx
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
Jul 07, 2010 | Graco Alano Travel System 7F08DSW3...
Don't know how to replace insulation in nozzel
The heat resistant mica sheets simply wrap around the heating element separating it from the inner nozzle.
Below is a link to a diagram that is pretty much the same as yours.
http://images.google.com/imgres?imgurl=http://www.howardelectronics.com/MasterAppliance/Image/explo_mhg.gif&imgrefurl=http://www.howardelectronics.com/MasterAppliance/hgreplacementparts.html&usg=__7eMZnaHCciQBDezdWd5n_NOLy_0=&h=309&w=600&sz=16&hl=en&start=19&sig2=BF0jaBHxYQfJyuxn7P4eig&um=1&tbnid=lWkvIGGrzK4WTM:&tbnh=70&tbnw=135&prev=/images%3Fq%3Dheat%2Bgun%2Bparts%26hl%3Den%26sa%3DN%26um%3D1&ei=w-plSrWnNY74NdK-hZEB
Apr 20, 2009 | Master Appliance 750-1000D F PRODUCTION...
Nails jammed in stapler so I took it apart splitting the halves.
Without knowing the brand and model number, the best I can offer is this: Since your question is listed under "all Black and Decker nail guns", have you tried going to www.blackanddecker.com and searching for your tool, or contacting their support section on the website? Or try typing your make & model # into a search engine, pick a place that sells parts and ask them to fax or e-mail a copy of the diagram (I have done this before to get diagrams).
Mar 11, 2009 | Black & Decker Tools & Hardware - Others
Putting the gun together
hi can you send me a pull down giude for winchester .22 model 250
Mar 08, 2009 | Sport & Outdoor - Others
Not hot enough
being a digital heat gun i would say that the onboard circuitry is only allowing it to heat up to a lower temperature , for what it would cost to fix its probably cheaper to buy another one but i would stay away from anything digital and try and buy a wagner or bosche if you can but non digital
Sep 28, 2008 | Ace Hardware Ace Digital Heat Gun
Garden Logo
148 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
