Question about Canon EOS-20D Body only Digital Camera
Canon EOS 20D with stuck lens
Dear Smilemaker
Thanks for your suggestion. Can you clarify which button you mean by the 'OK' button.
Many thanks
Mike672
    Genius:
  • 1,027 Answers
The OK button is the center button on the back-side rotary dial (just right of the LCD display)
Posted on Jul 15, 2008
  • 790 Answers
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
Posted on Jul 08, 2008
What is error 99 in canon eos 20d
It's a frustrating catch all error and needs service.The camera may have any one of numerous issues or lens issues. If you have more than one lens, see if the error occurs with both lenses on. If not then it's a lens error. A camera repair facility can plug unit the camera and download a more accurate troubleshooting code. Royal Camera Service in Hanover Park, IL is good source for this problem. The replaced the shutter on my 20D when I got the error 99 code.
Feb 06, 2013 | Canon EOS-20D Digital Camera
I have a canon eos 20d that has become permanently attached to a canon 75-300 zoom lens. I cannot detach the lens and fear if I force it it will break the camera and/or lens. The lens is more than 5...
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed. if it dint work let me know
Regards
Smilemaker.
Jul 08, 2008 | Canon Cameras
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
Jun 29, 2009 | Tokina 12-24mm /f4.0 for Canon
I am trying to find a eos digital solution disk to purchase for the canon eos 20 d
Hi there.
Go here and download all the drivers and software you need for canon digital camera's >>>>
http://www.canon.ca/english/index-customersupport.asp
Good luck and thanks for using FixYa!!
Mar 15, 2009 | Canon EOS-20D Digital Camera with 17-85mm...
Canon eos 20d giving false error message
CF means that it can't read the compact flash socket on the side. I had a similar problem on one of my bodies. I would try either a different (new or one that hasn't been in the body) with a freshly charged battery. If this doesn't help, you can only send it in for diagnostics and repair
Jan 05, 2009 | Canon EOS-20D Digital Camera
Canon EOS 20D Digital zoom failed
The autofocus mechanism on some lenses can be damaged if you manually focus while the camera is attempting to autofocus. Basically, you would be working against the motor and gears.
There is no need to download software before using the camera, however, I would suggest going to Canon's website and downloading the firmware upgrades for it. Here's the link:
Canon 20D Firmware Download
Hope this helps!
Oct 12, 2008 | Canon EOS 20Da Digital Camera
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
Powershotsd1000 problem
Hello!!
Regards
Smilemaker.
Jul 19, 2008 | Canon PowerShot SD1000 Digital Camera
Soft Images
Have you done the basic unsharp masking after RAW processing? Normally you'll find a 500% strength, 0.3 pixel and a threshold of 1 or 2 brings out the detail masked by the AA filter very well. DOn't bother with the sharpening in PS ACR....it's too crude and doesn't account for how big an enlargement you'll be making. In other words, there's no control. Best of luck....
Sep 14, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Canon EOS-20D Body only Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
