Question about Kenmore Dishwashers
I have a kenmore model 665 and the unit wont drain.
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back with complete model# for any further assistance.
Daniel
Posted on Jan 01, 2011
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Kenmore Ultra dishwasher model 665 wont drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 11, 2011 | Kenmore 24 in. 16032 Built-in Dishwasher
I have a Kenmore ultra wash model 665, stock# 15951. When the tub starts to fill the water runs out the drain.
This means there is either an air gap in the drain hose or the drain hose loop is less than 32" high preventing back flow
Sep 18, 2010 | Kenmore 24 in. 15159 Built-in Dishwasher
My kenmore diswasher model 665 15772 - lock button is flashing - dishwasher will not start. Can you help me?
6/3 I bought a Kenmore Ultra Wash dishwasher, Model 665. As many others have posted, my dishwasher also do does not automatically drain, leaving about 3" of water in the bottom of the machine. The only way to pump the water from the machine is to use the Drain/Cancel button, which cancels the cycle, and the dry option, leaving the dishes wet and spotty.
I just contacted a tech rep with Sears Repair and was told this is a Factory Defect with this model. Whirlpool (manufacturer) is aware of the problem and working on a resolution. Meanwhile, Whirlpool (via Sears and K-Mart) offers a free service call to install the "retrofit kit" that should solve the problem.
Even though Sears is aware of this problem, you will be expected to jump through their hoops - did you install a disposal at the same time and knock out the plug (FYI - if the plug is not knocked out, the Drain/Cancel option will not work and the machine will not drain at all). They will also ask if there is anything blocking the drain (FYI - if there is a foreign material block of any kind, the Drain/Cancel option will not work and the machine will not drain.
If this dishwasher (Model 665) does not drain automatically, THIS IS A FACTORY DEFECT. A retrofit kit is available to correct. In the DC Metro area, the wait time for an in home service call is three weeks.
If you have this problem, call Sears 1-800-4MY HOME and schedule a FREE retrofit kit installation
ALSO, call your sales person, and the appliance dept manager, at the store where you purchased the appliance to let them know this product is defective.
Jun 26, 2010 | Kenmore Dishwashers
My Kenmore 665 will not drain!
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 31, 2010 | Dishwashers
Built in modle 665 does not drain
I am assuming that the modle 665 you are refering to is the first 3 characters of the model number???
if your unit is making all the normal noises it should make when draining, yet is not ejecting any water, or is leaving some and another drain cycle is necessary to remove all water the drain tube that screws into the pump/motor assembly may be cloged with larger than recommend particles that have made their way to it.. usually things like cupboard door bumpers that fall off into the unit get ground down till they fit through the chopper plate but are still to large to fit easily through that tube..
remove the kick plate below the units door, place a pan, etc under the drain hose where it connects to the tube, remove the hose, then unscrew the tube and check for obstructions..
hope this helps.
best of luck,
ttfn
Oct 24, 2009 | Kenmore Dishwashers
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
My kenmore ultra wash model #665 does not pump out water.
my model #665 dishwasher will not pump water into the unit
Apr 25, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher doesn't drain fully
Some model 665 DW have a check valve that is attached between the sump and drain hose that may have a blockage..... Remove the drain hose from the long plastic valve then carefully unscrew the check valve from the sump. Inspect for debris.
Jan 03, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwashers Logo
127 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
