Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
I have a Frigidaire 30"
  • 4,323 Answers
Hi
To remove the main top:
1. Lift the front of the main top and disengage the lift and lock rods.
2. Lift the top up and forward.
3. Slide a putty knife between the main top and the control panel to disengage the hold down clips, one on each end.
Hope this helps... Please post back with complete model# if you need more information.
Daniel
Posted on Jan 01, 2011
All 5 spark igniters not clicking
Could be range of problems including:
Power not connected/turned off
Ignitor ports clogged
Incorrect operation
Manual is available via Google
Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
Prob light stays on, prob is not connected. Will not allow me to heat the oven to a proper temperature or to turn off. Tried unplugging. Frigidaire fggf3054
Press the probe button and hold for 6 seconds.
Press self clean and toggle until "continue" message appears.
Press start to accept.
good luck!
Nov 27, 2014 | Frigidaire Gallery FGGF3054M 30"...
Does my griddle pan on my Frigidaire 5 burner
I just got a new range and the instructions to season the griddle are in the instruction book. Wash an d dry the griddle. coat all surfaces ( top and bottom ) with a thin coat of cookin oil. place in oven at 350F for one hour. turn off afer an hour and let cool in the oven.
Jul 02, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Getting stains off burner caps on ge
Gently use a steel wool - or you can put all of the grate assembly pieces on self clean in the oven, wipe when finished.
Oct 15, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
My frigidaire ES400 gas range is giving off a sooty smell and high levels of CO that fluctuate from 23ppm - 118ppm (FD CO METER). what is the possible cause and how can it be repaired?
Air intake needs adjustment. Remove bottom drawer, there is a gas valve and the burner attached to it. Loosen small screw on the burner and turn the air baffle to let more/less air in. If not sure what you're doing - call a repairman.
Also make sure not to cover any vents on the oven bottom with foil, as some usually do.
It also can be that the burner holes need cleaning
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Self cleaning oven
http://www.frigidaire.com/support/Result... just need to identify exactly which model you have and download your manual. May your burners be eternally clean Hope this helps :)
Mar 14, 2007 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
104 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
