Question about Memorex Audio Players & Recorders
I have a Memorex VCD8MMO and the cds will not play or stop in the middle
Why is my jvc boombox playing CDs with squeaky noise
Did you try different CDs? sometimes it's just one particular CD.
Try to solve it by cleaning optical reader wirh a CD cleaning kit
For your better information look up this site
Memorex CD and DVD Lens Cleaning Kit
May 14, 2015 | JVC Audio Players & Recorders
Question
You might need to clean the lens. They have CDs that will help clean this.
Aug 28, 2012 | Memorex MVD2016 DVD Player
Memorex cds won't play in home player when burned, but will play in computer or car player. The file is not a mp3, it is a audio file created by windows player, or ITunes. Neither will play. Other cds I...
Not every CD or DVD player is able to correctly ready every single brand of writable media. The situation you described is quite common, and the only solution is to use another brand of media. Some people recommend burning at a slower speed, but I don't think this helps at all.
This situation might be caused by incompatibility between the laser on your player and the formulation of the writable surface. You should test other brands and find one that works with all your devices. When you find it, stick with it.
Mar 03, 2011 | Pioneer Audio Players & Recorders
My Memorex MX4118 no longer has sound when CDs are played. The display shows the CD tracks and progress while "playing" but no sound. Used a cd lalser lens cleaner but still no sound.
If it's clocking time on the disc predictably don't mess with the laser.
http://www.retrevo.com/support/Memorex-MX4118-Radios-manual/id/1082dj096/t/2/
Is the CD indicator lit? See page 18.
Press the PLAY/PAUSE > '' / POWER ON button to select CD; the CD indicator will appear in
the display.
Feb 03, 2011 | Memorex MX4118 Shelf System
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Is the memorex 9290 recorder a quality unit
memorex record to CDs --- CD will not play on other units
Feb 22, 2009 | Electro Brand Nostalgic Stereo CD Music...
Memorex dvd/cd
replace the spindle motor and optic lens.
Apr 22, 2008 | Memorex MVD2022 DVD Player
I can't seem to play memorex cd's on my computer. I've downloaded musi and one cd has family photos on it, but for some reason it wil not download on my computer.
It has nothing to do with memorex. There are few possible causes. Perhaps you're using incompatible format (CD-R, CD+R...). Also, perhaps those CDs were burned on another computer and left unclosed. Check the CD format and check if the CDs are closed or opened for additional files.
Apr 21, 2008 | Computers & Internet
144 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
