Question about Dryers
Sounds like a bearing is out. i would like to fix myself
    President:
  • 2,468 Answers
If its a front load and sounds like a jet plane taking off when in spin cycle,yes its the drun bearing(s) inner and or outer and the lip-water seal on the outer rear drum area,it takes a while if they get stuck bad,be careful driving out the bearings as if you shatter the outer plastic tub they cost about $500.00 to replace so don't hammer on the bearings too hard and use and let sit in penetrating oil before trying to hammer out
Posted on Jan 01, 2011
My Maytag mah5500b front load washer makes a loud knocking sound when spinning. It sounds like a problem with the drum. Can I fix this myself?
Could be the bearings or the "spider", the mechanism that holds the drum and is attached to the bearings at the back of the drum. If one of the arms snaps or the bearings go then it sounds really noisy. These are replaceable, but can be expensive and difficult to replace. It may be worth weighing up the repair cost with possibly only a 3 month warranty on the work versus a replacement machine and its' warranty.
Sep 01, 2015 | Maytag Neptune Washing Machines
I have a maytag neptune, model # mah3000aww. Its making a loud howling sound during spin cycle.
It sounds like the drum bearings may need replacing. This is not a small job, so be sure of what you're doing before you attempt to fix it yourself. Please feel free to get back to me for instructions on replacing the seal and bearings.
Jul 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Loud noise while spinning,like a bearing going out.If it's a bad bearing,can I fix it myself?
Yes you can. It is a big messy job. It takes me about 2.5 hours to do by myself. Good luck.
Jun 19, 2011 | LG WM0642H Front Load
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
My Maytag Performa dryer is making a horrible sound...still working though. Wondering if it is a belt?? Can I fix myself?
go to Sears and purchase the belt with an idler pulley with it. It comes as a kit. The pulleys bearing has dried out bearing that went flat in spots which causes this horrible noise
the top and the front of your dryer needs to come off to access these parts
Jan 13, 2011 | Maytag Dryers
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
I think the driver side rear wheel bearing ..2000 tiburon
Yes it is the rear bearing. It can be a home fix but you will need good tools and some spare time. Log on to the Hyundai Coupe Owners Club in the UK for guidance.
Oct 07, 2009 | Hyundai Motor 2000 Tiburon
92 geo prism just installed both cv axles'but getting a grinding noise from left inner side.sounds like a bearing breaking up.but it comes and goes.how hard to fix myself? could this be the bearing the cv...
it could be the wheel bearing have you checked thefront brake pads and have you checked that the backing plate you havent bent and it is toutching the disc this some times accures good luck Lindz
Mar 29, 2009 | 1992 Geo Prizm
Kenmore elite dishwasher making loud buzzing sound when washing
it sounds like a broken empellar in the pump like there is a piece of it broken off and ratteling around in there... change the empellar
Feb 21, 2009 | Dishwashers
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
