All of a sudden, my dell laptop will not connect to our home wifi but works fine with an ethernet calbe when run from the router to the laptop. It worked fine one time but not the next.
  • 600 Answers
Try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---TRY IT NOW-- If stiil no connection then--go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
follow this is a link to a troubleshooting flow-chart-DO check it out
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If you continue to have problem..indicate at what point in the flowchart it is getting stuck
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Posted on Jan 01, 2011
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
Desktop will not connect uless wireless is active.
your laptop is most likely set as main pc,you will have to changeI your settings make sure both pcs are set to home and to share networks.you may have to play with the wifi settings to.
Oct 21, 2009 | Linksys WRT160N Wireless Router
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
File sharing between computers
Thanks for giving me the opportunity to help. Try the following:
On your laptop with Vista, click start, then network from the right side. This will take you to the Network Screen. Click on the Network and sharing screen. Click on options such as file sharing, printer sharing etc. Make sure that you can see each device your your network. If you can't you must go to each PC and use the network options on the XP machines. It's pretty simple, just follow the instructions that the wizard provides.
I hope this gets you up and running. Thanks for using Fixya.com
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Computer file sharing
first check,
laptop and pc is in same workgroup.
then,Right ckick on the file---------------share and security-------------cilck on blue under line like if you understand security risk....................................--------------then choose just enable file sharing---------ok
its done!
Jan 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Home network printing- How?
you can share the printer so that your laptop can use it also look in to adding your printer to the router so its on the network
Jan 25, 2009 | Computers & Internet
Can't get internet access!!
The proper procedure in any router based network is to get the router on the network first. Plug it into the online cable modem and boot it up. Let it sit for a minute and then boot up wired computers one at a time. Use one of the wired PC's to get into the routers GUI (eg. 192.168.1.1) and see if WiFi is turned on and the permissions or wireless access is not being blocked by any security settings like MAC address or IP filters. It should be wide open. You dont need ANY drivers for a router on a PC unless they are USB drivers for a USB connection straight to the router, never seen one but I have seen a cable modem/router that had a USB connection. If your laptop has a USB wireless device, you need to load the drivers for that onto your laptop, but if it is using the built in ethernet port on the rear or a PC card ethernet card, you just need to plug the ethernet cable to the rear of the router and boot up. Make sure your ethernet device is enabled in windows and you should be good to go. After you gain access to the internet on the wireless device, get back into your router, prefferably on the wired computer and lock your network down with security measures like MAC address filtering, WEP, or other means.
May 16, 2008 | Compaq Computers & Internet
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Laptop wifi connection problem
Reinstall wifi driver and check the IP address
Nov 21, 2007 | Dell Inspiron 1200 14.1 XGA LCD...
Computers & Internet Logo
David Payne
David Payne
