Question about SkyScan 86709 Atomic Wall Clock
I have model# 88202cop. The battery lost it's power and it wasn't replaced for some time, the battery corroided and the circuit board lost some of the green stuff. So I need to get a new "guts" of the clock. Is this possible for joe homeowner to replace and can I get the parts cheaply enough to make it worth while to fix the clock? thanks, Bill
  • SkyScan Master
  • 277 Answers
Posted on Oct 03, 2016
5 Suggested Answers
  • 31 Answers
SOURCE: I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
http://skyscan.info/content/manuals/25-model-86709.html This is the direct link to the manual.
Posted on Nov 16, 2011
agent91
  • 2100 Answers
SOURCE: time setting for skyscan model 88202cop
The clock sets itself, I have never touched mine, it just works, and unless you are sitting on a time zone, it should work. There is a set button in the back , I have never messed with it, It has an alarm on it too. Hope this helps.
Posted on Jul 18, 2010
Testimonial: "Great, simple instruction. Thanks..it works !!!!!"
You have to press the time zone button while holding down the small reset button with a pen, toothpick, etc.
Posted on Mar 20, 2011
gopakumarg43
  • 74106 Answers
Hello
Get into this link. You can see the user manual for your Skysacn atomeic clock here. You can adjust your clock according to it manual. OK.
http://www.atomicclocksstore.com/skyscan-atomic-clock-manuals
Posted on Nov 11, 2011
Lost picture I have sound on my TV but lost picture NS-32D511NA15.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 24, 2017 | Televison & Video
Tip
Craftsman belt drive garage door opener intermittent
My opener was flaky- intermittently going on and off. I could bang it and it would do the same thing so this suggested a loose connection somewhere. This wasn't a unit with the battery backup.
Safety note- don't take apart unless you first unplug the entire unit!!! I took it apart and there were two circuit boards- a logic board and a power supply board (latter was smaller of the two). I took out the power supply board and examined the solder joints on the back. I found one that was cracked (this soldered a connector pin), and another that looked like it wasn't good (not shiny). I resoldered and this fixed the problem.
Another time my wall control acted up (this has the IR sensor and buttons). There is not much room around the screws on the backside for connecting the wires. One of the wires was a little long and shorting out to a nearby component.
Hope this helps someone with similar problems.
on Aug 26, 2015 | Building Materials
Sansui 0523 lost display, turning on but no sounds
Jun 14, 2017 | Sansui Televison & Video
Sva ed4218p, just lost picture, was working fine and then no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 17, 2017 | Televison & Video
My Soniq tv has lost picture but I have sound. Is it time to get a new tv?
Jan 15, 2017 | Televison & Video
Samsung UN40JU6500F had picture on intial power up, changed source and lost picture. Can't get it back, only sound. See faint images. Bottom back shows blue lights on. Inverter? Power board?
Jul 26, 2016 | Samsung UN Televison & Video
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
2002 Nisssan GXE lost power
It sounds like the battery terminals and/or alternator wasn't hooked up properly. Try checking all connections once again.
Nov 01, 2012 | Cars & Trucks
About nikon L1 fuse on circuit board..
when you reinstall the batteries... check again that the plus and minus posts of the battery are correct
Robert
Jan 20, 2009 | Cameras
Proton Model RS-420 clock radio lost power back-up
The battery is located on the display circuit board at the front of the unit. It's a bit of a pain to get to.
You'll need to open the case, unplugging the wiring harness plugs so you can take the two halves apart. Next, remove the strip of circuit board at the top where the snooze/alarm and other top button switches are. Then you will be able to get to all of the screws holding the display circuit board to the front of the case. The battery is soldered to the board. I'm not sure what type or voltage it is, but it's probably a single-cell NiCd at 1.2v. I think the best replacement would be a supercapacitor but I need to figure out exactly what the battery is first.
It's a great radio that's worth fixing. If anyone can tell us what the battery is, please post! Mine says "860" on it.
Cheers,
- Phil
Apr 30, 2007 | Proton R5A Clock Radio
SkyScan 86709 Atomic Wall Clock Logo
275 people viewed this question
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
