Question about Canon MP610 Photo All-In-One Printer
Cannot turn on printer. changed outlets in a different room. langhorne pa 19053
  • Canon Master
  • 6,771 Answers
Check to make sure the printer cord is properly secure in the machine, failing that! the power supply is defective and to repair it would not be cost effective. A new replacement is recommended.
Posted on Jan 01, 2011
I cannot turn it on...when I use the same cord on other printer/scanner, the cord is still okay..so this means that the problem is on the printer/scanner....kindly advise what to do....
Since the power cord works on a different scanner, this means the power supply unit inside the printer has failed. In most cases, this costs more to fix/repair than a new printer.
Feb 28, 2011 | Office Equipment & Supplies
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
Just replaced the ink cartridges. Printer keeps telling me to turn it off then on. However, it fails every time I turn it on again.
With the power cord connected and the unit on, disconnect your data cable(s) from the printer (USB, parallel). Press the power button to turn off the unit; wait 15 seconds and then turn the power on again.
Check if the error comes back. If it doesn't, reconnect your data cable(s) one at a time, checking for the error message between adding each connection. If you see the error, replace that cable.
If the error did come back after cycling the power when no data cables were connected, you have to look at your power cable. If the cable has a power module (box that you plug another cord into), make sure that you have the correct one for the printer.
In either case, unplug the power cord from the back of the printer (first) and unplug it from any surge protector or power strip (second). If you have a power module, unplug the cord from that and reconnect. Wait 30 seconds. Plug the cord directly into the wall outlet and then into the back of the printer. Then turn on the printer.
Check for issues. If the printer turns on, you may have overloaded the power strip. If it doesn't turn on, you should check the outlet for problems. Try using an outlet in a different room (preferably a different circuit breaker). (Move the printer and its power cord.) If the printer still doesn't work, replace the power cord or module.
If none of the above works, the printer needs service.
I hope this helps.
Aug 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Different outlet went out after installing dimmer.
It's possible that he living room outlet feeds through the dining room switch and that a wire may have become disconnected when you put in the dimmer. I don't know the specifics of you home layout. If the dining room and living room are on different circuit breaker switches, this is not the problem.
Feb 28, 2010 | Electrical Supplies
Hp psc 1401 printing slow problem
Reset and relocate the productA power reset drains power from the product and returns the product to the same settings after restarting. To eliminate any potential power deficiencies that might hinder a successful alignment, HP suggests you move the product to another location and plug the product directly into a wall outlet. Follow these steps to reset and relocate the product.
  1. Press the On/Resume button to turn on the product.
  2. With the product turned on, disconnect the power cord from the back of the product.
  3. Relocate the printer to a different power outlet, preferably an outlet in a different room.
  4. Plug the power cord directly into the wall outlet. Do not use a power strip, extension cord, or surge protector. CAUTION: Do not reconnect the power cord to the back of the product at this time.
  5. Load letter or A4 size unused, plain white paper in the tray.
  6. Reconnect the power cord to the back of the product.
  7. Press the On/Resume button to turn on the product. The product automatically prints an alignment page.
Oct 13, 2009 | HP PSC 1401 All-In-One Printer
Imaccurate directions, from my house
Try putting your gps on the shortest distance not the scenic route. That is in the system menu area.
Aug 18, 2009 | Magellan GPS
We moved the washer to a different room. When we
Was the place where it was the original laundry room. If so outlet was probably a dedicated line not hook to any other outlets. Now you moved and plugged into outlet that is not dedicated other items are probably being used on same circuit or breaker is to small, should be 20amp.
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Problems with Brother MFC-7820N Laser Printer turns itself off
I just had same issue, it shared an outlet with a large volume work group copier, I unplugged it, opened and closed all compartments to make sure something open was not causing issues. I plugged it into different outlet and it appears to be back online. I have read some postings that this model has been known to draw over 15 amps. Its possible its starving for power. To test take to another room, plug in outlet by itself and see if it boots up.
May 29, 2009 | Brother MFC-7820N Laser Printer
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Printer takes a long time to start
Hi! Sorry to hear of this issue! There are a few steps you can do to diagnose the issue. If these steps do not work, let me know and I can suggest other steps or which part you may need to order. I can be emailed directly at: bosscomputers@comcast.net or http://bosscomputers.org Follow the steps below to ensure power is properly supplied to the printer: Check the power module part number against the part number listed in the User?s Guide to ensure the proper power adapter is being used. Disconnect the power cord from the wall outlet. Disconnect the printer data cable from the printer. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning. If the power cord does not work on the other printer, it is defective. Replace the power cord. If the power cord works on the other printer, then this printer is defective. Service your printer. If another printer is not available to test with, carefully inspect the power cord for damage. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer. Again, if these steps do not work for you and the issue is still present, then the printer will need a specific part - and I can tell you how to order, install, etc, so that you can do the repairs yourself! =) Just email me at bosscomputers@comcast.net Please rate my help for you too, so that I can track your progress as well as helps me get a better rating =) I really appreciate that, as well as hopefully being able to get your issue resolved/fixed!! ~Darrin~
Jun 10, 2007 | HP DeskJet 890c InkJet Printer
Canon MP610 Photo All-In-One Printer Logo
141 people viewed this question
old marine
old marine
