Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Hi i got a old school suzuki **** and everytime i go to put gas in it and turn the gas switch on,it starts pouring gas out of the carb so if yu could help me out with resolving this that would be much appreciated
    Genius:
  • 2,028 Answers
Your floats in the carb are stuck. Take the float bowl off and clean the floats with a carb cleaner, it may also require an overnight soaking in a solvent, parts cleaner, or degreaser. Depending on the condition, they may need to be replaced.
Posted on Aug 06, 2008
On a suzuki gsx400f how do i set mixture on carbs
The year makes a big difference, but normal carb mixture starting position is 1.5 turns out, not all the way in. But mixture normally does not effect starting. Usually backfiring is timing or jumped chain? But can happen if a float is stuck and gas pouring in.
May 30, 2015 | 1981 Suzuki GSX 400 F
97 Suzuki intruder 800
Drain the carb floats and clean with Seafoam. Gas breaks down after about 6 months and the ethanol in the gas coats the carb.
Oct 12, 2013 | Suzuki Motorcycles
Wont start but has gas going to carb
check the solenoid on the bottom of the carb make sure it has power and is opening old fuel causes them to stick and bad safety switches keep them off
Jun 23, 2012 | Garden
Can not remember where hoses from carbs go, disassembled 4 months ago, cleaned carbs and put bike back together , now gas pours out of air box, are the hoses inbetween carbs 1&2 and 3&4 vent lines,...
Hi Clintster999, I am sorry you can't find the first and best tool you ever bought for your Suzuki but despair not for a mere $15.00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
1997 Suzuki Motorcycle Service Repair Workshop Manuals
Aug 08, 2011 | 1997 Suzuki GSF 1200 Bandit N
My 300 utility seems to flood out everytime I try to start it. I have rebuilt the carb, including replacing the needle valve. After it turns over for 4-5 times, gas starts pouring out of the carb. I do not...
the needle is not seating with the float which is causing the carburetor to flood. either the needle is not attached to the float(some snap into a plastic groove, others have a spring) or the float is bad. Hope this helps Tim
May 29, 2011 | Desa International Garden
Gas leak on my Suzuki VZ800 Marauder
Its the carburetor need to be cleaned probably stuck float or needle seat old gas will do this becomes thick with age. next time you store it drain the carb and if you can fill the carb with carb cleaner then drain that away.
Apr 28, 2010 | 2000 Suzuki VZ 800 Marauder
Suzuki katana 600 not running
check your starter switch, it may be even grounding, which would cause all these problems
Jul 30, 2009 | 1992 Suzuki GSX 600 F (Katana)
Gas is draining out of the bypass tube?
sounds like the float is stuck in the carburetor
Apr 15, 2009 | 2003 Suzuki RM 125
Gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Jan 29, 2009 | Garden
I have a 1981 Toyota 4WD with a 22r engine. Truck has been sitting up for about 8mos. I purchased it and got it home. The only way I can start if is by pouring gas in carb. I have replaced all vac lines...
check the fuel pump, maybe it is not working. if you put a new accelerator pump, I wonder if it's same as the fuel pump. if so, maybe you need to rebuild your carb, clean the small fuel line in the carb, something block there.
Jul 27, 2008 | Toyota Pickup Cars & Trucks
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
