Question about Traulsen RLT232NUTHHS Commercial Freezer
How do you clean the filters Do you just brush the dust off
    Guru:
  • 1,524 Answers
Wash with warm soapy water.
Posted on Jan 02, 2011
How do I clean the coils?
One of the best ways to clean the coils is with a shop vac and a coil brush. A coil brush is a cylindrical brush 1/2" to 3/4" diameter with a long flexible handle.Schaefer brush makes a good coil brush or a bottle brush duct tape to along handle will work in a pinch. The fins can be fairly fragile so use care in cleaning them.
Hope this helps
HTTPS:// Schaefer brush.com
Sep 22, 2015 | Freezers
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Clean heat dispersal fins
There is a good chance it is located behind a panel in the back where the compressor is located. The other location would be underneath the refrigerator behing the front grill. A vacuum and brush will do the job.
Mar 25, 2014 | Bosch B22CS30SNS Linea 300 Series Counter...
Freezer runs and sides are hot
Good Morning bigred140, thank you for allowing me to assist you!
From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around your refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can typically locate one on the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your freezer) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Best regards, Chris.
Dec 22, 2013 | Frigidaire FKFH21F7HW Freezer
Sides of upright freezer are very warm to the touch
Good Afternoon Chuck, thank you for your inquiry! From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the freezer. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
Aug 21, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hot side panels
Hello Robert - From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site. If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachement and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath refrigerator. Cleaning condenser coils typically resolves this issue. But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Apr 24, 2013 | Frigidaire 13 cu. ft. / 368 liter Chest...
Sides of freezer warm to touch when starting doesn't at all ; defrost timer stuck in on position?
That is because part of the coils run thru the cabinet to help release the heat the refrigerant is removing from the freezer coils , to make the freezer cold . Also make sure the coils are clean from dust , pet hair , etc . And make sure the fan by the compressor is running . Nothing to do with defrost .
Aug 30, 2009 | Freezers
Not cooling it is on and has been working fine, but woke up today and everything is melting- being thawed out - freezer is not cold
You need to check Condenser -
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Good Luck!!
Thanks
Jul 19, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Problem with hussmann chest freezer
If the freezer is not located in an area where grease vapors are present the unit can be cleaned off using a vacuum cleaner. Then use a flash light to look through the coils. If you see dust embedded deep inside use a small air compressor to blow out the dust. Dirty condenser coils raise the pressures and temperatures in the system. Cleaning the coils and scheduling them to be clean at quarterly intervals should keep it functioning for a long time. Operating with a restricted condenser takes its tole on the compressor life span.
Sep 01, 2008 | Hussmann Freezers
Traulsen RLT232NUTHHS Commercial Freezer Logo
52 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
