Question about Kohler Home
Kohler toilet model # K84591 constantly runs. How do I stop this?
All three of my new kohlers do it its not the valve or the float look closely and you will see a kink in the chain going from the lever to the cyl. terrible design and there the only ones I have seen with this design I have bought my last kohler product they could have fixed it for a nickle instead they lost a customer for life
Posted on Jan 13, 2011
I have a hissing toilet. My kohler 4708 fills up, and once this happens, the left side of the tank has a constant hissing sound. When I turn off the water it stops.
Your valve inside the tank has worn down and not allowing the water to stop running. Does the water run over the top of the overflow. If so, then adjust your inlet water to a lower level so it will cut off. If that is ok, then likely the flapper is worn out and needs to be replaced.
Feb 19, 2013 | Kohler Home
I have a kohler model 703 # sb78drn, the toilet keeps running. i changed the flapper and now the toilet doesn't stop running. please help?
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Mar 04, 2011 | Kohler Toilet - One Piece with Ingenium...
We just installed the Cimerron two piece. After flushing the toilet, it will not stop running. Water just goes into the over flow section.
  • The exact cause of a Kohler Cimarron toilet running non-stop depends on the exact model of toilet owned. In some, the lift chain connected to the handle can become kinked, preventing the ball seal from covering the drain completely. Just unkink the chain to fix this. In other cases, the float ball is stuck against the side of the tank, preventing it from returning to its normal horizontal position. When this happens, the toilet's tank doesn't stop filling with water. The excess continuously flows into the overflow pipe. Dislodge the float ball from the side of the toilet and this should clear the problem. Likewise, you might consider shortening the armature on which the float ball sits, so it won't become stuck again.
  • Read more: Troubleshooting a Kohler Cimarron Toilet ' eHow.com http://www.ehow.com/how-does_5017443_troubleshooting-kohler-cimarron-toilet.html#ixzz1CxKmz9ZQ
    Feb 04, 2011 | Home
    Float does not trigger valve to stop water - continues to run even though tank is full
    What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
    Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
    http://www.plumbersurplus.com/pdf/1058802_2.pdf
    Jan 29, 2011 | Kohler Toilet - One Piece with Ingenium...
    Toilet doesn't turn off after flush
    The Kohler Cimarron is one of the most popular and reliable toilets out there. (My Favorite). However, depending on the hardness of the water and if you use cleaner tabs in the tank, these factors can lead to a malfunction.
    The first thing you should do is hold the flapper (rubber seal inside the tank that releases the water down to the bowl) down with your hands for a few seconds after a flush and see if the toilet stops running. Sometimes the flapper doesn't seal properly therefore the fill valve keeps working non stop. Stopping the fill while holding the flapper down will confirm that your flapper needs to be changed.
    If this doesn't work then try this....
    The other common problem with a running toilet is with the fill valve itself. There is an attached float on the fill valve that goes up and down depending on the water level. Once the water level rises, it rises the float, and the float tells the fill valve to stop filling the tank. While the toilet is running (hissing), try raising the float all the way up with your hand and see if it stops. If it stops but not consistently with every attempt, then you will need to change the fill valve. I believe the Fluidmaster 400A is the replacement model.
    Nov 23, 2010 | Kohler Cimarron Comfort Height elongated...
    I have Kohler toilet ...I believe it was a Rialto model....the numbers inside the tank are T33 K2402P3 ...
    picture is of a kohler rialto
    looks like you can get the parts or retro fit newer kohler flush parts
    ring around for a plumber or kohler toilets seller that can supply kohler cystern parts
    Apr 28, 2017 | Home
    My toilet runs constantly
    How old is the toilet? Might have lime buildup in the housing that's keeping the float from raising completely. The whole assembly is relatively inexpensive at Wal-Mart, and very easy to change. It would probably be less hassle than trying to fix the old one. I found that out after wasting a lot of time trying to mix my old one. :-)
    Aug 30, 2009 | Kohler Toilet - One Piece with Ingenium...
    Home Logo
    469 people viewed this question
    Top Kohler Home Experts
    Donni Steen
    john h
    Tim Whalen
    Are you a Kohler Home Expert? Answer questions, earn points and help others
