Question about Spinmaster Zoobles Small Playset with 1 Zooble Under the Sea
Zooble won't open. - Spinmaster Zoobles Small Playset with 1 Zooble Under the Sea
  • 8 Answers
My daughter's zooble was stuck closed and this zooble would not open even when placed on its special magnetic zooble stand. We solved the problem by sticking the cap of a pen into the back of the zooble's head to release the catch. A paperclip works too, but not as reliably. After looking at the internal latching mechanism, I would not recommend trying to force it open. She made a video to demonstrate.
Posted on Apr 17, 2014
  • Danielle Criddle
    Danielle Criddle Sep 03, 2014
    thank you so much for posting this online
Trunk won,t open so I can get to boot to open mu gas tank
Have you checked the fuse panel for blown fuses? If not, check there first. If so, check to be sure all the wiring harnesses in and around the fuse panel are tight ans secure. If you're really in a pinch and you have rear folding seats you can crawl into the trunk that way.
Jul 24, 2013 | 2003 Audi TT
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Fuel door won't open
Fixed. In the glove box there is a vallet button. I pushed it and now my trunk and fuel door work. and what this has to do with my trunk and fuel door not functioning , I have no idea. Hope this helps someone else.
Apr 05, 2012 | 1998 Cadillac DeVille
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
Hi. our little purple penguin zooble will not open. any tips? thanks.
Jun 20, 2011 | Spinmaster Zoobles Spring to Life Gift...
Spinmaster Zoobles Small Playset with 1 Zooble Under the Sea Logo
2,914 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Terry
Terry
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
