Question about Philips Health & Beauty
Our Phillips HX6710 rechargeable toothbrush doesn't spin. Is the battery replaceable? At two likely locations to find a battery, there is a no-battery symbol. We lost our manual.
4 Suggested Answers
  • 10 Answers
SOURCE: What symbol is used when the battery needs to be
battery's life is governed on the number of recharges. so it is always recommended to recharge a battery only when it has been discharged completely. generally a blinking battery symbol denotes that the battery needs recharging.
Posted on Aug 07, 2009
  • 86 Answers
SOURCE: On the 28th January 2011
Hi penguin33879,
I work for Philips, and I came across your post while visiting Fixya. I wanted to share with you the link for registering your Philips Sonicare:
http://pnregistration.harte-hanks.com/sonicare_registration.aspx
You can also shop online, search for product information, and find support by visiting www.philips.com.
I hope this helps.
carloffb
Posted on Feb 08, 2011
SOURCE: electric toothbrush,WHERE IS BATTERY COMPARTMENT
They are usually sealed (waterproof) units without access to batteries
Posted on Nov 25, 2012
Why is it making a loud noise after reacharging,never before
Are you sure the brush attachment is "tight" to the handle? Do you have a new brush to try? It should confirm handle is bad or it is the brush attachment "tightness" .
Mar 11, 2015 | Sonicare Phillips Philips Sonicare...
How can I register my razor in the UK?
Go to Phillips UK, register on-line. Follow the link
Aug 02, 2014 | philips consumer lifestyle PT730/41 Power...
I am currently using the electric Phillips toothbrush. Would like to change the batteries but having problems removing batteries with all the glue. Did not want to damage circuit board. Need more...
Take a look at this video from YouTube; hopefully it will help you to remove the battery from your philips toothbrush.Good luck
http://www.youtube.com/watch?v=UdWX155Kmq8
Feb 10, 2013 | Sonicare Phillips FlexCare RS930 / HX6932...
What are the different types of toothbrushes?
There are three types of toothbrushes that are commonly used:
  1. 1. Manual toothbrush
  2. 2. Rechargeable electric toothbrush
  3. 3. Battery power toothbrush
For more detailed information on these toothbrushes, check out Oral-B website
Jan 10, 2013 | Health & Beauty
Electric toothbrush,WHERE IS BATTERY COMPARTMENT
Nov 24, 2012 | Irons
The toothbrush no longer holds a charge. The light on the toothbrush doesn't light up.
Hi!kindly check the battery of your toothbrush if it is good.And check also the charger of your toothbrush.
Sep 11, 2011 | Home
My oral b rechargeable toothbrush (brand new out the box at the weekend) wil not recharge - have thrown the intructions away thinking "what is there to know you stick the toothbrush on the charger...
The plastic connecton has a coil in it, much like how a transformer is done. If you read up on how a transformer works its pretty much the same principle as it works on Induction. There is a coil and core iron in the end of the toothbrush and in the base, this creates AC current which inturn causes induction to flow through the coils and charge the battery. And about the reason why it is not charging is probably down to the battery being flat ( happens even when new ) or there is a loose connection when it was being transported.
Hope this helps.
Mar 22, 2011 | Oral B Vitality Dual Clean Rechargeable...
Dear Sir, Madam, I have a tooth brush by Braun : Oral B Triumph 5000. I am not able to recharge the battery any more.What should I do ? Thank you in advance for your answer. Best regards. GH. Leroux
Three possibilities come to mind ::
- the rechargable battery is dead and won't take a charge and needs replacing, or
- the charger is malfunctioning (broken wire or burned out transformer), or
- the electrical contacts on the toothbrush and the contacts on the charger are not making good contact (need cleaning or re-tensioning).
How old is the toothbrush ? Is there a charging light and does it light up when it's charging ?
Charlie
Feb 12, 2011 | Vacuums
My Braun Oral-B Sonic Complete Toothbrush wont hold a charge
I had the same problem today. I use the charging plug which has the "wrench" remove the bottom screw...I was attempting to remove the battery to reset the brush. I could not get the bottom of the brush off as I did not want to use a screw driver or similar to pry it off in case I needed to return the brush.
So I was trying to pull the bottom off and my finger was on the on/off switch, as I was wiggling the bottom of the brush to try to dislodge the battery it started working.
The brush seems to have a reset button on the back but that did not do anything. The display also has moisture trapped inside it, which I am sure is not good!
Any way try this and maybe the battery will come out and I am sure that will reset the brush...if not maybe you will get lucky as I did and wiggling it will work. BTW, this is with the Oral-B Triumph Professionla Care 9000
Apr 21, 2008 | Computers & Internet
Health & Beauty Logo
105 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
