Question about Miller Welding Tools
My Miller Matic 200 will not arc. I have checked all connections, tried to arc across the ground clamp w/ the wire, nothing....
  • 407 Answers
If everything is connected according to manual, then your problem must be contact box inside the machine. If it is a recent model 2005 or higher then it could be the main pc board. I would start by checking the ground cable and clamp first before send it to a repair shop.
Posted on Jan 02, 2011
How to connect a Miller welding machine
Do you need information on how to connect the electrodes to use it, or how to connect to your garage/shop/house's power?
If it's a different type of plug than your outlet has the ability to receive, it likely means it's a 220 welder (as most welders are), and you would need a 220 outlet to plug it into. In which case, you need an electrician or someone else capable of wiring and installing a plug for you.
If you're wanting to know how to connect the electrodes to use the welder, the negative (black, generally) clamp needs to be securely clamped to a (preferably bare) metal area near where you want to weld. Usually problems with good ground connections are caused by not having the ground attached to bare, shiny steel. If it arcs at the clamp, it means it's not grounding well enough to work properly.
Aug 25, 2015 | Miller Welding Tools
The arc sputters when welding. Tried changing the electrode tip and checked the ground.
I've had slot of experience with these migs. Usually when the arc sputters, it could mean 2 things, either the roller feed tension is too light, or the liner in the pistol lead is worn. It's the flex tube the wire travels through. If it's worn the wire will hang up or snag, causing the arc to sputter. If you tighten the roller tension, and the wire back-lashes, that's a sign to change the lead. First try adjusting the speed of the wire accordingly to the heat.
Jul 30, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
I own a Miller "Sidkick" MIG welder. It has been
Hi:
If everything works but there is no arc; you should check your ground clamp, make sure it is not loose or dirty including terminals and replace your gun's contact tip.
Believe it or not this is a simple one.
If this was useful to you please vote. Thanks
Feb 25, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
I have a miller 90 amp firefly xl when i'm
  • You can try changing the tip,
  • keeping your arc length shorter - closer to the weldment.
  • if your machine has a burn back function, set that to the correct setting, it may be set to something by default,or have moved (not available on all machines).
  • check your ground clamp - make sure it is clean and securely connected.
Apr 19, 2010 | Welding Tools
Millermatic 140 w/ auto set powers on but will not feed wire or arc
If its a new unit its probably nothing. Miller makes good stuff. Open the side so you can see the spool. With the machine on, press the trigger for a second. Did the little wheel spin (trying to feed the wire) if it did then your problem could be kinked wire, **** on tip, or spring on small spool is loose and wire is slipping. Let me know.
Nov 20, 2009 | Miller matic 140 Mig Welding Package W/As...
Arcing before pulling the trigger
does this unit have a high side and a low side if it does plug it into the low side and try it.
May 27, 2009 | Miller Welding Tools
The ground clamp has voltage
WARNING ! You have an earth leak on the unit, before you do any more work with this set, have it checked by a qualified electrician, it can be HIGHLY dangerous to continue. the leakage can be on the mains side and can cause you serious injuries. dont atempt to repair or examine yourself.
Dec 26, 2008 | Miller Welding Tools
Welding Tools Logo
163 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
