Question about Minolta DiALTA DI2510F All-In-One Laser Printer
Problem on Minolta DIALTA DI 251? my copiers haVE detected problemS, one says code C070 another one says code C0500 What are the problems?
  • 4,323 Answers
Hi
Error code C070 or C0070 is related to toner not seated properly. Power off the machine and gentlly take out the toner bottle. Turn on the machine without the toner bottle, let the machine go through its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
C0500 means Heating Roller warm-up failure. Open and close the right side door. There's a switch hidden under the frontcover activated by the side door. Sometimes the grey plastic arm attached to the sidedoor is not actuating that switch properly.
To reset the error Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter "3" from the 10-Key Pad when dot appears at the center on the left side of the screen while the start-up screen is being displayed. (Enter code 0000) You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or thermistor. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
Re DiAlta di 251
What about the Di251?
Jun 03, 2014 | Minolta DiALTA Di183 Copier
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Dec 08, 2012 | Konica Minolta Office Equipment & Supplies
Problem on Minolta DIALTA DI 251? my copiers haVE detected problemS, one says code M4 What are the problems?
Touch the Utility, Meter counter, Stop00 stop 01, now in service mode now stop 9 select copy kit counter then select mode 1
M-4 is set up to monitor what ever the tech wants it to be
Jun 08, 2011 | Minolta DiALTA DI2510F All-In-One Laser...
I have Dialta di 183 . the problem is when i power ON . it will automatcally OFF for a seconds.
Does show any code on the screen like C0500 or something like that try turning it on with the stop button held down to reset the fuser (THE HOT PART) also check make sure the electrical plug is plugged into the machine tight and snug, if not sound like a power supply problem, might want to get a konicaminolta tech to come out a look at it.
Jan 21, 2011 | Minolta DiALTA Di183 Copier
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta di 251 srror code coo7o
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Jan 11, 2008 | Minolta DiALTA DI2510F All-In-One Laser...
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
795 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
