Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue receiving DL error message. Any suggestions?
I had Same problem door wouldn't lock. i sprayed wd40 into door latch and shut the door several times and turned on washer a couple if times and then it locked. try this first!!!
Posted on Aug 22, 2014
  • 4,323 Answers
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
Door will not stay locked keeps displaying dl error
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Mar 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis washer has a dl code with nothing blocking the door. i have jiggled the grey wire on the control panel but that no longer helps.
Nov 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Lid lock will not lock.Getting "dl" error.
Oct 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Lid does not lock. When it DOES, it beeps and shows "dl" on the screen
Sep 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
On my Kenmore frontload washing machine, we are getting a DL error?
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The error "dl" continually comes up and we cannot finish a load of laundry
Jul 01, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t Washer door won't lock
Im assuming that the part number youve mentioned is for the new door latch assy?? Unfortunately the problem could also be in the Main CCU. Ive had several of this design have intermittent door lock codes and not lock the door....It was the CCU in most. This washer should have a full years warranty for parts and labor. Perhaps the sears people didnt understand its still under warranty. I wouldnt want for you to waste your money on the door latch if it is the Main computer. Also you may want to remove the top of the machine and check the wiring connectors going to and from the CCU and the latch.
Nov 25, 2007 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
432 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
