Question about Whirlpool Washing Machines
I have a whirlpool duet model # wfw9400sw02 . When I pushed the power button it would not come on . Then it showed an error message of F7 or F70 unsure due to unplugging the washer . Plugged washer back in and no lighting on the controls at all . It only beeps when pushing the power button . Purchase date of 10/21/09 .From Lowes No extended warranty
I have the same problem. I contacted Whirlpool,they said to call an electrician. Electrician said it was a MOTOR CONTROL BOARD. My price to fix in Fl. was $430.00, $400 for part and 30 labor. I had a coupon other wise it would have been right at $500. Hope this helps!
Posted on Apr 27, 2011
On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
F70 code says...
Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
The control board is part # 14 in the link below.
Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
Mar 13, 2015 | Whirlpool Washing Machines
I bought in June 2010 a Whirlpool Duet washer Model WFW9400SU00 Serial CSU2113432. Could not install it till April of this year and finally started using it in June for 6-7 washings, then the error F70...
F70 is "Central control unit heart beat failure" No communication is detected from the Central Control Unit to the User Interface. (In english, this means that the controler unit mounted in the bottom of the machine, probably in a plastic cover, has stopped talking to the control panel on the front of the machine where you push the buttons).
You need to take the top off the machine and check that the wiring harness between the 2 units is intact and that the plugs on the ends of the harness are firmly in place on both the Central Control Unit and the User Interface. If this fails to fix the problem, then the action indicated is that if the drum is rotating while this error is showing, the user interface is faulty and requires replacement. If the drum is NOT rotating while displaying this error, then the Central Control Unit should be replaced.
Jul 28, 2011 | Whirlpool Washing Machines
Error code F71 on my whirlpool Model WFW9400SW02 Front Load Washer
from what i have out it is it sounds like you need a new interface board,and if theres no warantry,it will be expensive to fix.
Jul 07, 2011 | Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F70 Message appears and dryer stops WORKING
The F70 error apparently is a design flaw that happens to many of these machines in this series. It has something to do with a failure of the components to communicate with each other. The main circuit board most likely needs to be replaced hope this helps
Aug 11, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Can anyone tell me what an F70 code is? When I push the start button it beeps at my twice and then in about 30 seconds I get a long beep and the error code F70 is on the display. Thanks in advance for your...
F70 error code indicates Central control unit heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Thank you !!
Jun 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
NO POWER JUST BEEPS F70 CODE
Bad main control or ccu here is a link to the repair manual.
http://www.affordableappliance.com/Download%20Folder/Whirlpool%20Duet%20Washer%20Service%20Manual.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
445 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
