Question about Whirlpool Dishwashers
White film on glasses and plates; I have cleaned tubes and nothing is blocking. is it possible that it is too much calcium/deposits; or a ring/gasket in the bottom sprayer that pre vents the water form spraying through the top and bottom sprayers
  • 4,323 Answers
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Posted on Jan 01, 2011
My Whirlpool dishwasher is leaving a serious layer of white deposit all over a;; dishware. Could be calcium. Never had the problem with it before. Help!!!
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 07, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Tip
Hard water Calcium white powder build up in dishwasher
Calcium and magnesium is present in a great number of homes today regardless of hardness or softness of the water. Water containing dissolved carbonates of calcium and magnesium can lower the effectiveness of the detergents you use and leave deposits on the dishware and tub of the dishwasher. When these deposits dry they become what some call lime scale.
To remove these deposits there are a number of cleaners on the market today. I will list them in the order of my preference. You can find them near the dishwasher detergents. If you use them read the instructions on the label, but basically you can run a cycle with no dishes and the cleaner. Some of the cleaners like Lemi-Shine can be used with a full load of dishware after you clean the tub. This helps keep the tub clean and deposits off the dishes. If you want a home remedy that seems to work pretty good, put a cereal size bowl upright in the lower rack (no other dishes in the dishwasher) fill the bowl with vinegar and run a normal cycle. The vinegar will wash out and clean some of the deposits away. If residue is still around run a second cycle of the vinegar wash.
- Lemi-Shine
- Finish Dishwasher Cleaner
- Glisten
- Glass Magic
Here are some links to other dishwasher tips I have put together.
Blinking Clean Light
Poor washing on the top rack or noisy
General Dishwasher Cleaning
on Apr 30, 2010 | Dishwashers
Steam holes on the plate are letting out limescale onto clothes, is there a way to clean out iron
Yes you fill the Iron with White Vinegar (the acidic Vinegar dissolves the lime deposits), and then flush with hot water, then clean the bottom with CLR (Calcium Lime and Rust remover) brand cleaner from any hardware store. This also is how deposits are cleaned out of a Coffee pot.
Jan 12, 2011 | Vacuums
How do I dissolve dishwasher calcium deposits w/o causing leaks
The best gentlest way that really won't harm anything except the calcium, is White Vinegar, mix up a solution and water, try a 75% mix first, and try that. T
Feb 24, 2010 | Dishwashers
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
The dishes do not get clean. Food is left on plates, in bowls, on silverware. Coffee stains are building in cups. Milk leaves a "film" on glasses. When the cycle is finished, it appears that the water...
Hi, it sounds like your dishwasher is plugged up with soap deposits, and/or Calcium deposits.
In an empty dishwasher, put 2 cereal/soup bowls full of vinegar on bottom shelf, and run your dishwasher.
This should clean out all the deposits.
I do this about once every six weeks as our water is very hard.
Fred
Sep 30, 2009 | Dishwashers
GE Profile PDW9200J dishwasher leaves a film and dirty dishes
Sounds like you have an excessive build up of hard water (mainly calcium) in it. Clean it like this: Close the detergent cup cover. Run hot water at the sink to clear cold out of the pipes. Start the machine on pots and pans/added heat. Wait about 10 minutes and open the door. If the detergent cup cover flops open, it is in the main wash. If it is still closed, let it run a few more minutes, check cup cover again, keep dong this until the cover is open. Once it is open it will be in the main wash (the longest cycle) and at that time put in about 2 cupfulls of Tang orange drink in the bottom of the tub. Tang is very high in citric acid and will clean the calcium and other hard water deposits from the tub, pump, spray arms, ect... Make sure your hot water is HOT (130 is great) and use Cascade Complete powdered detergent from now on. Should take care of it... Repeat every 6 months to keep it clean.
Dec 20, 2008 | GE 24 in. Profile PDW9200J Built-in...
Dishwasher leaves film, smelly water
You need to use something with citric acid too try and clean out the calcium deposits inside dishwasher, you can get cleaner at the store or run a can of frozen orange juice thru it or a small bottle of apple cider vinegar. Do this with no dishes inside.
Jul 14, 2008 | Whirlpool 24 in. DU900PCD Built-in...
Blocked steamer outlet /frother tube
hello take the pipe put it in a solution of calcium remover leave it in for a couple a day calcium in pipe is like concrete after a day or so try to pass a steel wire in it the calcium gonna get softer everything gonna come of after take the same product fill the machine run the machine with it for a good clean up most of the people loose good expresso machine because of hard water a clean up every few month it gonna work good and our coffee gonna be warmer .p.s when you use special cleaner rinse the machine very good the cleaner is very corrosif cheers
Jan 14, 2008 | Coffee Makers & Espresso Machines
Dishwashers Logo
78 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
