Question about Norelco 7800XLCC Electric Shaver
Shaver starts on it's own and won't shut off.
When I put my Braun series 7 in the cleaning station everything is good. It pumps liquid up to clean then it starts to pulse and the vibration shuts the system down. I redo it with the same result.
I wonder if you can charge the shaver with the cord. Or is the battery dead?
Please also check if the blades of the shaving head are pressed on correct. It is the cleaning system, what pumps up the fluid, and after a while is the the shaver that should start pulsing. So it must be an error with the shaver. If the shaver works normal but does not when not in the cleaning station, also check the contacts on the shaver and on the cleaning station.
Jan 10, 2015 | System Clean 6 Braun Syncro Shaver & Renew...
R9370 won't work
Any corrosion on the rechargeable batteries usually means that they've gone bad.
For an relatively easy to fix test, disconnect one end of one of the cells wherever it's easiest to solder back together. Then plug in the shaver and see if it works. The LCD may not work, but the shaver itself might.
Looking it up further, I see that it uses a 12VDC cord/charger. So if you try my suggestion, the LCD and shaver should work when plugged in, if the batteries are the problem.
Sep 25, 2012 | Remington Health & Beauty
Razor heats up when i charge it and it won't turn on
Most likely, the batteries are bad. If the charging light still illuminates when plugged in, you should be able to change the batteries to fix the problem.
You will find the correct batteries for model 4865XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Scroll down the page for helpful tutorial videos
Oct 11, 2011 | Norelco Micro Action Shaver 4865XL...
Norelco 4805 xl razor won't turn on when plugged in nor will the battery charge. i would think it was the battery but it does't want to turn on when plugged in either. is the motor shot? thanks
When the battery goes completely bad, the shaver will not work even from the cord.
You will need to open the shaver and make sure that the batteries have not corroded badly and damaged the inside of the shaver.
You will find the correct replacement battery offered at shaveroutlet.com. See link below
You will also find a video tutorial on this page to halp show you how to open the shaver. See link below for another video with additional installation tips
http://www.shaveroutlet.com/shaver_battery_replacement
Jun 10, 2011 | Norelco Micro Action Shaver 4805XL...
My toshiko trimmer is not getting charged, even after charging for 6 hrs it works hardly for 5 seconds and stops.what should i do?
mcdevito75 here, Sounds like the batteries won"t take a charge anymore. Refer to the Toshiko website at Tosiko.com for battery replacement, however at times the batteries cannot be replaced as they are attached to a circuit board and, you"d need to replace the shaver.
Jun 21, 2010 | Toshiko Shaver/Trimmer Set Electric Shaver
After soldering new batteries my shaver´s on-off switch won´t wor
it sounds like you may have some sloppy solder which is causing a continuous connection here there shouldnt be
Dec 24, 2009 | Norelco Rechargeable Cordless Men's Razor...
My unit won't turn off.
I have a Remington electric razor fully charged and it won;t shut off unless I plug it iin. When I remove the plug in cord it runs all the time?
Dec 14, 2009 | Remington MS5500 Electric Shaver
Norelco 7800XLCC Electric Shaver Logo
48 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
