Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Why does standby light keep blinking constantly and picture keep flashing off and on
  • Sony Master
  • 467 Answers
Could be any one of a number of factors, including:
a) a protection circuit could be malfunctioning;
b) your flyback transformer is arcing, hence the flashing picture;
c) power supply is not oscillating at the correct frequency, causing varying HT and affecting the line output stage;
or
d) worst case scenario, your CRT could be shot, which would make the set uneconomical to repair due to tube replacement cost.
DON'T PANIC ABOUT THE CRT JUST YET: I would advise checking every component (look for dry solder joints and resolder accordingly) on the main board thoroughly, starting with the power supply and working towards the horizontal output stage, in particular checking all the tuning capacitors in the collector circuit of the output transistor, making sure none of them have dropped in value, as well as the transistor itself.
Once you have completed all checks, if it turns out the flyback transformer is the true culprit, replace both this and the horizontal output transistor with correct type numbers. You should be able to order new ones. This is just a starting point suggestion here, but it may bear fruit and could save you hundreds of dollars in workshop charges/fees.
Posted on Feb 14, 2011
2 Suggested Answers
SOURCE: standby light blinking
power supply
Posted on Jun 26, 2008
Sony LCD TV Red LED light constantly blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 06, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Hi y Beko tv is 7 years old. Suddenly the picture keeps flashing and wont stop. There is sound but picture is constantly flashing. I cleaned any dust off. The model is. 32WLJ520HD.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Feb 17, 2015 | Beko Televison & Video
Sony Grand WegaKDF-E50A10 standby light constant flashing green
Sounds like the main system control-chroma IC fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 09, 2014 | Sony KDF-E50A10 50 in. LCD HDTV
Philips 29pt828c/25 crt tv won't turn on, the red standby light is constantly flashing. Have unplugged and left for days and then switched on it powers up, get picture and sound and then say 4mins later it...
The flashing light indicates a fault. These flashes are called blinking codes. Count the number of blinks occur at one time switch ON. Counting of blinks to Philips is not done directly. It is a sort of coded. If you wish to get more details, check the site linked here. Counting procedure to Philips TVs is given in detail. Please keep some time with the instructions. It will be somewhat seem difficult to anybody who doesn't know anything electronics. http://electronicshelponline.blogspot.com/
Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 15, 2013 | Televison & Video
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Red light keeps blinking when I try and take a picture
actually the flash ckt is having problem that is the reason the red indicater blinks. you can take photographs with flash off mode,to solve this problem you will have to contact service centre
Dec 08, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
