Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
White westinghouse 8cycle washer will not spin or drain now it wont do anything model number WW5833ES1 i thought it might have been circuit related so i reset the fuse box and removed the clothes from the washer i tried to restart the load but now its not doing anything
    President:
  • 2,468 Answers
Does it fill with water yet?if so then its the lid safety switch that gone bad under the top lid,this will kill all cycles other than fill,if it doesn't fill with water either then the timers defective
Posted on Jan 01, 2011
Kenmore 70 series model 110.20722990 wont drain and spin
It could be the timer or circuit board, until it is not draining, will not spin
If the timer or circuit board is OK, the you have a faulty drain pump or motor, to check this out remove the back panel.
Mar 12, 2013 | Kenmore 22422 Top Load Washer
White-Westinghouse wash cycle not engaging
Likely transmission failure. The motor controls agitation as well as draining
Feb 26, 2013 | Washing Machines
My Frigidaire Commercial Series FCCW3000FS 27" Coin Operated Front-Load Washer will not agitate or spin clothes out. Please HELP!
You should check your serial number at this link:http://www.cpsc.gov/cpscpub/prerel/prhtml09/09292.html
There was a voluntary recall issued on your model number. The serial number will confirm if your machine is affected.
As to your problem, i would still suspect drain pump is struggling or inoperable. However if it seems to drain ok and your pump is still relatively quiet except for a nice mellow steady hum (there should be no rattling sound) then i'd take a look at the pressure switch. The pressure switch sends the signal to begin agitation (water level in tub is full) and spin (water in tub is drained.)
Jan 03, 2013 | Frigidaire Commercial Series FCCW3000FS...
My wfw9050xw stoped in the middle of a wash. It wont spin, drain,wash or do anything. when I unplug it and plug it back in, I can press the control button ang og to drain , but it spins about 3/4 turn and...
Anonymous:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 07, 2018 | Whirlpool Duet WFW9050XW Washer
When the washer enters the spin cycle, it doesn't speed up, leaving the clothes still soaking wet when done
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 21, 2010 | Westinghouse Washing Machines
My washer starts of just fine but when going in spin cycle its slow and wont drain belt looks good,its just looks like the motor wont go into high speed
heatman101
Sep 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
White Westinghouse model #MWX413REW The
Belts can wear out from: Overloading, old age, or stretching. Sounds like a new belt is in order for you.
To see the specifications and schematics for this machine, and how many belts it has, type your model number into the web-site "SearsPartsDirect" when you are asked to .
God bless your efforts.
Dec 21, 2017 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
692 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
