Question about Refrigerators
I have a Kenmore side-by-side refrigerator. It has been tripping the circuit breaker for a couple of days and now temp is droping in the fridge and freezer.
  • Refrigerators Master
  • 43,501 Answers
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 01, 2011
Kenmore ref model 795.73266303. After power outage fridge won't turn on. Lights inside work but the digital thermostat is off.
Check the parts list at the link below to see if a circuit breaker is present in your fridge, it could have tripped if incoming line problems were unstable:
KENMORE TOP MOUNT REFRIGERATOR Parts Model 79573266303 Sears PartsDirect
You can also order needed parts from those pages.
Jun 25, 2015 | Kenmore Refrigerators
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
. I have a Kennmore Coldspot Fridge that runs for
A 15A circuit is mainly reserved for lighting.
Even some vacuum cleaners would trip a 15A circuit breaker.
The problem isn't with your refrigerator...its with the breaker installed in the breaker box.
Check your wire size and follow these rules :
12 gauge wire can have 30A c/b max
14 gauge wire can have 20A c/b max
16 gauge wire can have 15A c/b max
So, if the wires coming out of the wall socket is 12 gauge or even 14 gauge...you should be able to swap that 15A circuit breaker with a 20A circuit breaker.
This should be plenty for your refrigerator...if it "pops a 20A"...then you've got appliance problems.
If you don't feel comfortable doing that...then get a new 15A breaker...because it sounds like the other one has gotten weak.
Hope this helps
Jul 23, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridg pops circut breaker,
Sounds like a shorted heater. You advanced manully, unit runs till timer goes to defrost. Timer contacts switch, defrost heater shorted trips breaker.
Apr 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Whirlpool Refrigerator Tripping Breaker
check voltage check fan could be compressor or to much load on the circuit with fridge
Apr 07, 2009 | Whirlpool Refrigerators
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Dec 12, 2007 | Refrigerators
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
