I am experiencing low water level. - Washing Machines
  • tomsekera Jan 01, 2011
    I'll look into that solution. The make of the washing machine is Frigidaire Electrolux. Model number: FTF530FS3. Front loading machine.
    Thank you.
    Is part #17 the float switch assembly? Would you happen to have a part number for that part?
  • 1,998 Answers
What is the model number of your machine? Have you checked the water valve to assure that both sides of the valve are working if they are not then you would either only be getting hot of cold into the machine also have you checked the pressure switch which tells the machine how much water its supposed to have in it to wash if the switch is stuck down then you would have low water inside your machine please message me back with model number and your finds while inspecting your machine with the model number i can also send you a schematic diagram of your machine as well if you have any other questions please message me back and please remember when our chat is concluded to rank how this opinion has helped thanks again Rick
Posted on Jan 02, 2011
  • 4,323 Answers
Hi
Low water level is due to faulty float switch or siphoning issue with your washer. This may occur if air is trapped. This may also happens when the drain hose is not correctly installed and drain water is flowing back in the washer. You would need to check the drain hose, fill hose and float switch assembly to figure out the exact fault location. Hope this helps... Please post back with model# if you need more information.
Daniel
Posted on Jan 01, 2011
  • Daniel Scott
    Daniel Scott Jan 01, 2011
    Hi
    Please check hose (part#45) in link 1 and part#17 in link2--
    Link1
    Link2
    Hope this helps... Please post back if you need more information.
    Daniel
  • Daniel Scott
    Daniel Scott Jan 02, 2011
    Yes you are right part#17 is the float/pressure switch which you can buy from this link.
What does it mean when water level is low
It means that there is a bad water switch on the water fill sensor or stop
Aug 22, 2015 | Hobart CL44E-8 - Left To Right 30-kW...
Water level sensor
The 'low-water' sensor installed in a bathtub is designed to NOT allow the pump to run without water contacting it.
It sounds as if this is operating as it should.
Once the pump comes on you should be able to touch the "logo" or the on/off button to turn the pump on and off.
If the pump is not turning on/off when the tub is full of water you may be experiencing a problem with the control box under the tub skirt.
Rod
US Parts Center
888-521-6183
Mar 20, 2014 | Jacuzzi Home
Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na Leaks water and high copper in my water
It sounds like your water has either been running at a low pH level, or you have a salt system. Basically your heat exchanger coil has dissolved into your pool water.
The exchanger can be replaced although it is pricey. I would recommend replacing it with a cupronickel coil. This is far more resistant to the type of corrosion you have experienced. Just be sure to keep a closer eye on the pH also.
Feb 19, 2013 | Sta Rite 333 Btu Natural Gas Heater...
I had an American Standard Cadet3 Right Height Elongated toilet installed. After flushing, water level in the bowl drops to a very low level. Enough remains to prevent gasses or orders, but just enough. I...
Adjust the water setting of the tank to higher level, meaning an additional water will be added to the tank. The purpose of this is to release extra water that will fill the missing water level in the bowl.
Nov 10, 2010 | American Standard 2002.800.021 Champion...
Dolphin Dishwasher, Why do they have a low water level sensor on the wash tank for, since the water level always over that level.
This sensor is there to warn you in the event the water level is too low to properly clean the dishes
Sep 19, 2010 | Dishwashers
What is E no 1 on washing machine wa13G7Q1
Hi
Error code 1E means WATER PRESSURE SWITCH ERROR. This error occurs when the Generated Frequency Signal of water level is low or high.
WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the Water level is detected as low or high for more than 5 seconds, then it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 minutes after which you would get this error. To resolve this issue you can try and clean the filter screens inside the water lines. To check this disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back. This will resolve the issue.
Daniel
Sep 01, 2010 | Samsung Washing Machines
If my oil light is flashing does that mean its low . and if its low what kind of oil should i use . its a 2003 honda cbr 600 f4i , also the bike gets hot on the temp guage after riding only 15 minutes ,...
It comes on every time the oil pressure falls below a preset level. If you are running out of oil (because the level is low), then 1) shame on you for not checking the oil level frequently! It's not like you have to lift the hood, or anything hard like that, and 2) don't drive it at all until you get some oil in there!
If you have plenty of oil, then you could have a stuck oil pressure relief valve, a blocked oil pickup, a worn out oil pump, an unbelievably clogged oil filter, or an internal oil leak (from a crack, or something coming loose).
In a water cooled car, the water only does 60% of the cooling. Another 20% is by aire passing over the engine surface, and the rest is carried to the oil sump to be cooled by air passing over the pan. Motorcycles have highly finned oil sumps for a reason: They shed a lot of heat through the oil. If you are low on oil, you will be low on cooling, too.
If you fill up with oil, but you still overheat, you probably have an excessively lean fuel mixture. If that is the case, and you let that continue, this bike won't last very long.
I just checked and found that this is a water cooled engine. So yes, you probably need coolant -- check into that right away. If the water pump gets dry even for a split second, the seals (lacking the lubrication that the water provides) will be destroyed -- it happens instantly.
Jun 14, 2010 | 2003 Honda CBR 600 F(4)i
Raising water level in the toilet bowl. Crane toilet. Don't see where any adjustments can be made. Water level in reservoir tank is up to the inlet tube. How do i get the water level in the bowl to be...
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Feb 28, 2009 | Crane Plumbing 3755 Toilet-To-Go Metro...
Neptune water level
ck drain hose level ..end should be 30-36 inches from floor also be sure hose fits loosely in standpipe ..possible water is siphoning out after fill up since these are low water use machines any drop in water level can cause problems
Sep 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
