Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My Epson Stylus CX5400 goes through the entire printing process, but what comes out of the machine is extremely faint and sparse - not readable at all. I've replaced all of the ink cartridges. What else could be going on?
  • Epson Master
  • 6,826 Answers
1) Click on the printer icon and check to see if there is an ink saving feature on this printer.
2) The following link takes you to the nozzle check section of the FAQ's.
http://files.support.epson.com/htmldocs/cx54__/cx54__rf/wwhelp/wwhimpl/common/html/wwhelp.htm?context=EpsonHelp&file=problems.htm#wp999216
3)On Apple computers the wrong driver may be installed.:
function setViewedFAQCookie(oid, foid) { var viewedCookie = "EP_viewed_faqs" + oid; var viewed = cookie.Get(viewedCookie); var viewedS = new String((viewed == 'null') ? '' : viewed); var found = viewedS.indexOf("" + foid); if ( found == -1 ) { var newViewed = foid + ((viewedS == '') ? '' : (":" + viewedS)); cookie.Set(viewedCookie, newViewed, null, "/", ""); } } Q: Since I upgraded to Macintosh OS X 10.5 (Leopard), my printouts are faint. What should I do? A: Make sure you're not using the Macintosh OS X 10.5 Gutenprint driver. Follow these steps to check if you're using the Gutenprint driver and change it if necessary:
  1. From the Apple menu, select System Preferences.
  2. Click Print & Fax.
  3. If necessary, click once on your printer's name in the Printer list. (You don't need to do this if only one printer driver is installed).
  4. If you see Gutenprint next to your printer name, go to step 5 to change the driver. (The Epson Stylus Photo RX620 appears in the example below, but you'll see your printer or all-in-one name instead).
    If you see only your printer's name, you're using the correct driver, and you can skip the remaining steps.
  5. Turn off the printer.
  6. Click the sw_mac_2_er.gif button to remove the printer from the Printers list, then click OK.
  7. Turn on the printer. Your computer should add the printer automatically.
    If your computer does not add the printer or if it adds the Gutenprint driver again, contact Apple for assistance. You may need to reinstall the Epson drivers provided with Macintosh OS X 10.5.
    Note: To check ink levels, click the Utility button, then click EPSON StatusMonitor. The Supply Levels button will not show remaining ink
Posted on Jan 01, 2011
  • Duane Wong
    Duane Wong Jan 01, 2011
    If the nozzle test shows output that is ok, then the problem may be traced to a software or firmware update that is required to make the printer output quality images.
Epson Stylus CX5400 will not print. This printer was unused and stored for 3 years. We replaced the ink cartridges and cleaned the print head and aligned the print head and ran a nozzle check. The printer...
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
I havent used it in months i shake the inks and they have some inside but when i try to print i get a blank page
It seems that Epsons ink clog up after sitting.
You may need to bring the headd over as you were to change cartridges and remove them.Unplug machine.Now take 5 or 6 drops of ammonia and put them in the ink well hole.Re-install carts and let it sit for 45min to one hour.Plug back in and do a nozzle check.If someyjing comes out but faint repeat process until happy.
If this does not work you may have to get a new head,usually less expensive to invest in a new printer.
Always run a test page weekly on an Epson to prevent this from happening again!!
Jul 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
My Epson Stylus CX5400 won't print.
hii,
u printhead block..that why cannot ink cant not get trough from the print head..or try clean the print head using printer properties under maintenain .for informations epson print head are sensetif..
Oct 25, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 prints bands of color
directly hooking the printer to mac and windows computer are you getting bandings still? interesting issue... we will isolate it first by trying to hook printer directly to both computer, if its printing fine when directly connected, then there is something on the application or communication process. try printing a different document using same application when on the network and try printing from different application as well. update me afterwards..
Apr 03, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Doesn't print correctly
print a page of solid colour..but donot print the entired page..maybe a third without wasting ink.
these printers are pigs when it comes to their printerhead
Nov 10, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400 problems
Sound like print head is you problem, are you using epson gen inks? ussally heads clog due to dodgy inks running  threw machine, If it isn't under warranty replace with new
Oct 18, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 prints blank pages
I've had this happen twice with the CX5400. I've fixed it both times by following the instructions on this page: http://inkjetprinterhelp.us/duraink.html (This involves dissassembling your printer so it's not for the faint of heart!)
Oct 11, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
