Question about Nikon Optics
Where can I purchase a replacement Nikon TGS-1 target sight for my Prostaff spotting scope? thanks, Dennis Kolson
  • 5 Answers
SOURCE: I'm missing five (5) Nikon rifle scope ring screws.
i would contact cabelas they have a full line of nikon rifle scopes or look up on line a company called brownells it is a gunsmith supply company they will have what ya need hope this helps ya and good luck
Posted on Mar 01, 2009
  • 8 Answers
SOURCE: sighting in, clicks don't move where they're supposed to.
Ja, it's 1/4 M.O.A, so at 25 yards/meter it'll be ca 3 inches. You may have gone in the wrong direction. That is, if it was 3' high, and you went another 3 higher then you'd be at the top of the paper. Probably you've got it figured out by now.
The easiest, fastest, cheapest way to zero is with a rifle rest you can clamp your scope into, or alternatively somehow immobilize your rifle some other way. You take a shot, at 25 yards or so. It makes a hole. You now immobilize the rifle, via your rest or heavy sandbags, with the scope pointing exactly where you aimed before. You now, carefully and without moving the rifle/scope off of the point of aim, dial your reticle to point at the actual bullet hole. Your next shot will be at your point of aim now. So you just put it at the right height above your point of aim at 100 yards now.
Posted on Nov 26, 2008
fps353535
  • 99 Answers
SOURCE: Ruger 10/22 Scope problem
This happens will all firearms. what happens when the bullet leaves the bullet is a decieving "rise" of the bullet. The reason for this is the Line of Sight (Scope View), angles down and away from the Line of Departure (Barrel). The bullet actually never rises and is in fact continally falling away from your rifles Line of Departure but because this is higher than the Line of Sight the bullet seems to Rise than fall to the set distance in the scope (i mention set distance and not zero because you can change your Minutes of Angle on your scope to increase and decrease range)
http://www.rifleshootermag.com/shooting_tips/ballistics_0303/
this is a chart that illustrates what i just said.
now that you understand that you should take a good read into Exterior Ballistics. this is the Mathematics of your fireamrs trajectory ( I say your firearms because your bullet's flight depends on the length of the barel which will vary from gun to gun) this science of shooting will teach you how to understand bullet Grain and Volume relations. understanding the Feet per second of your rounds and how the affects you. teach you about shooting in high pressure and low pressure environments and extremly windy environment.
now there is alot of math to all of this and its hard to find it all on the net and if your not that great at math you can do what i do bc im lazy and im not a sniper im just a hobby kinda guy. '
Sierra Infinity V 6 Ballistics Software. I dl'd mine off the net you might have to buy it depending on how resourceful you are. it is well worth the buy. You can punch in the daily variables (Barometric Pressure, Temp, Humidity, and Altitude) (of couse with your bullet as well) and it will give you a "Cheat Sheet" for those conditions stating Windage and Elevation adjustments per decided incriment (50 yrds is standard) then you take that to the range and (bring a laptop if you got it and arent embarrased (som1 might even help you tune in the variables) hope this helps if not ill check back in a bit to see how you did
Posted on Apr 07, 2009
  • 75 Answers
SOURCE: how to sight scope in /what scope do i have ?
Real simple Scott.
You can 'Zero' your scope/rifle even if you don't have a laser bore-scope device.
All this is assuming that your used rifle has not had the barrel shot out and that the head-space is still within specs for that rifle. Have all this checked by a gunsmith first. You can dress up a piece of poop and it will be pretty, but still be poop. Make sure yours isn't to begin with. As for the scope, it's hard to tell unless there's obvious damage or it's an antique past it's prime. Try to get as good a quality scope as possible to start with. You would not put one ply tube tires on your mustang and expect to get the best performance, so...
Most rifles are capable of shooting quite accurately, and all things being equal, it's the shooters job of making it happen.
Ammunition should be considered as well. Toss your old military ball ammo and junk from overseas, both of'em. If you want to shoot accurately and consistently, you must spend the bucks for the best ammo you can afford.
You MUST KNOW what the BALLISTICS are for the Cal./type/weight ammo you will be shooting and the corresponding distance it will be shot from.
Make sure your rifle is CLEAN inside and out. A clean rifle is a happy rifle.
Make sure that your rifle 'fits' your body's frame and that you are familiar and practice good rifle shooting techniques.
'Zeroing' is best done from the prone position as that is the most steady position to shoot from.
Do you have a bi-pod attached? Whether you do or not, sandbag your rifle securely but still able to make small adjustments to the rifle position itself.
Set up a target with a 1" black dot at 50rds.
Remove the bolt.
Lay down with your rifle but stay OFF of it, touch it as little as possible at this point.
With out disturbing the rifle look through the bore downrange to your target. Locate the black dot and if necessary adjust your rifle from the **** end until you can see the dot through the bore. Keep making minor adjustments until the dot appears to be centered in the bore. Make sure rifle is secure and steady at this point.
Then without moving or touching the rifle, look through the scope using the correct eye relief distance and locate the black dot. Now using the Vertical(Elevation) and Horizontal(Windage) adjustment knobs, move the reticles(crosshairs) until they both are centered on the dot.
Again look through the bore to make sure that you have not moved the rifle and that the dot is still centered in the bore. If not, adjust the rifle again to center the dot, then go back to the scope and adjust as necessary to move the RETICLES to the center of the dot. It may be necessary to repeat this a few times before you have achieved this particular goal.
You do not mention brand/model of your scope. It probably adjusts the reticle or crosshairs in 1/4minute increments (1/4 inch increments with each individual click movement of the turret knobs at 100 yard distance). IT IS CRITICAL for you to know how your own scope adjusts.
Now, bolt back in and load 3 rounds of quality ammo.
You are going to shoot 3 rounds in succession without getting off the rifle or making any adjustments to the rifle or scope. You are looking for a 3 shot group to determine a rough average of how far and where the rounds are impacting initially. Use good shooting techniques, breath control, relax, sight picture, squeeeeeeze the trigger, follow through the scope, there is no need to take your eye off the scope while doing this, hold your shooting position for all 3 shots.
You will now have to make adjustments of the scope unless you are hitting the black dot already which is quite possible.
Remember that if your scope is a 1/4" adjustment at 100yds, it means that for each 'click' that you adjust either Vertically or Horizontally at 100rds, the reticle/crosshairs will move accordingly 1/4 of an inch Vertically or Horizontally. At 200yds, one click will move it 1/2 inch, at 300yrd it will move it 3/4 of an inch, at 400yrd, it will be 1 inch.
Right now you are at 50yrds distance from your target. Each click from here will move the RETICLES about 1/8 of an inch so estimate the distance that your most central shot of the 3 you fired, is from the black dot and adjust accordingly. You're not moving the RIFLE here, you are simply moving the scope RETICLES so that your point of aim and point of impact coincides.
Now load 3 more rounds of ammo and repeat as above. You should only have to use about 9 rounds to get on target, the black dot.
Once you are hitting the black dot at the 50yrd line, move back to the 100yrd line. Put a fresh black dot on your target and repeat the steps from above. Your first 3 shots from the 100yrd line should be about 1/2 to 1 inch low. Don't follow the bullet strikes! Keep your point of aim and the crosshairs ON the black dot no matter where the bullets are striking on the target. Remember, now at 100yrds your RETICLES will move 1/4inch with each 'click' of adjustment of the turret knobs.
Adjust the scope as needed at this point. Once you are 'ON TARGET'(hitting the black dot), you now have your 100yrd. 'ZERO'.
Now that you have this 100yrd ZERO, you must loosen the turret knobs , both the Vertical(Elevation) and the Horizontal(Windage) turrets and align the '0' on the knobs with the '0' on the scope at the base of each knob. Now tighten the set screws and you are set to go. If you want to know your 200yrd 'ZERO', simply move back to the 200yrd line, your 'come-up' or elevation adjustment should be about 7-9 clicks, at least for .308 168grn HPBT, but you will figure it out for the Cal./brand/wght ammo you are using. WHATEVER the 'come-up' you need to make at 200, 300,400yrds or wherever, be sure to make note of the number of clicks you used to find the Zero for that distance. Use a fine point endelible marker and actually write the ZERO info on thestock of your rifle. You don't need to mark anything for the 100yrd ZERO, it's a given already. Write; 200/9, 300/18 and so on. You should also get your ZERO for the intermidiate, 150yrd, 250yrds etc, distances as well.
Remember that weather conditions, source and intesity of light conditions, your own body condition at any particular moment or day can have an affecf on how you and/or your rifle shoot. Good luck.
Posted on Apr 21, 2009
indy650
  • 30 Answers
SOURCE: I have a CZ in 223. Used their mounts on a
You need either medium height or high height scope mounts to fix your problem
-John
Posted on Jun 18, 2009
Cannot set wind age and elevation on a Nikon pro staff riflescope (not enough adjustment )
Check you mounts. If mounted properly you should have enough. if they are not moving at all you have prob broken the fine wires that form the crosshairs.
Jan 07, 2013 | Nikon 3-9x50 Prostaff Riflescope In Matte...
I lost the instruction manual for my 3x9x50 nikon prostaff scope.I would like to find another one so i can properly site my scope in.
Here is a link to where you can download the manual
http://support.nikonusa.com/app/answers/detail/a_id/14383/~/nikon-riflescope-instruction-manuals
Hope it was helpful?
Jan 30, 2011 | Nikon Rifle Scope Prostaff 39x50 Matte...
Is it possible to adjust the factory setting parallax on Prostaff for air riffle use?
It is possible but not advisable. It should be done by a professional and requires special tools.
If you have a spring loaded gun, the binary recoil will destroy it in short time. If it's a PCP, you want a scope with on-the-fly adjustable parallax for range finding.
My advice would be to change this scope for a dedicated air-rifle scope.
Aug 14, 2010 | Nikon 3-9x50 Prostaff Riflescope In Matte...
Scope for ruger 10/22 carbine
Google SWFA ......they sell about 20 different brands of riflescopes, with pix, desriptions and prices. It's a good source for info, even if you decide to buy one of the same scopes at Walmart. Check out the Bushnell Trophy, Nikon Prostaff, and Tasco scopes, in particular.
Also, there is a website I belong to, originally started just for the Ruger 10/22 owners/fans. You can visit it and join for free at - www.RimfireCentral.com
We have a great bunch of guys and gals there, who can help you with questions on ANY type rimfire rifle. I'm sure you will love this site.
Jan 21, 2009 | Optics
Jan 19, 2009 | Optics
Which knob for elevation/vertical adjustment?
usually side. best thing to do is go to an indoor range and sight it in. Just know the ballistic for the round/weapon you are shooting. ie. An M-16 has the same trajectory at 36 yds as 300, that way you can sight in at 36yds.
Dec 13, 2008 | Nikon ProStaff Rifle Scopes
Hunting
I have lost the adjustment knob covers for a nikon prostaff hunting scope in realtree camo. where can I purchase these?
Apr 21, 2008 | Optics
Optics Logo
211 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
