Question about Technics SA-AX910 Receiver
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Posted on Jan 10, 2011
  • wisdom
    wisdom Feb 14, 2015
    Technics SA-GX350 Overload problem is due to a MA700 diode D603 beside the relay just take it out and replace, it can work without it. it is driven by pin 18 of IC SV13206 vis R624 4.7k resistor.
Posted on Feb 14, 2015
How do i hook up my lg smart tv to my technics SA-GX350 stereo reciever
Connect audio outputs of TV to corresponding audio inputs on rear of receiver
Oct 22, 2016 | Technics Audio Players & Recorders
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Technics SA-GX350 Nonfunctional - Click, then nothing.
Please update the initial posting and continue the diagnosis there. The initial response is repeated below.
Thanks,
Dan
Initial response:
There could be a number of reasons for this. It woyld help if you could indicate what resistors you changed. The circuit designation should be marked on the PC board. Please post those here and I'll look further and provide some possible solutions.
Thanks,
Dan
Jul 20, 2009 | Technics Audio Players & Recorders
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Technics SA GX490 - Overload
yes it can be fixed , the input may have shorted and is now protecting the other circuits. it will need to be looked at and tested to make the repair. so calling and probably having to take it to, an electronic repair shop will need to be done.
Dec 07, 2008 | Audio Players & Recorders
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Nov 22, 2005 | Technics SA-AX710
661 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
