Question about Cameras
Do you carry instruction manuals for the Sony (UTX-B1) and the (URX-P1) wireless mic system
    President:
  • 2,761 Answers
FixYa.com doesn't "carry" any manuals, but you can download the one that you're looking for here:
http://pdf.textfiles.com/manuals/STARINMANUALS/Sony%20Mics%20and%20Wireless/Manuals/UWP-C1,%20UWP-C2,%20UWP-S1,%20UWP-S2,%20UWP-X1,%20UWP-X2.pdf
Posted on Jan 01, 2011
Testimonial: "You were the only one to give me the solution I needed. AAAAA+++++"
I need a user manual for a Sony Ericsson W595
Find help from these links:
www.safemanuals.com/???user-guide-instructions-owner-manual/???SONY%20ERICSSON/???W595-_???U
check these reviews too;
www.trustedreviews.com/mobile-phones/???review/2008/11/14/???Sony-Ericsson-W595/???p1
Sep 27, 2010 | Cell Phones
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
Sony microphone urx p1 stopped working
there was a loose connection in the microphone wire that needed to be resodered.
thanks Paula
Mar 30, 2009 | Sony (UWP-S1) Professional Microphone
Microphone holder to carry on belt?
If you are using the Sony UTX-H1 mic, google "Mic holster" or try:
Porta Brace Mic Holster, 10" Microphone Holster Case
Hope it helps!
Mar 22, 2009 | Sony (UWP-S1) Professional Microphone
I need help with my surround sound!!
The calibration mic thing is to balance the sound evenly on surround sound systems, it replacles the older systems "TEST TONE" speaker setup, in other words it will balance each speaker say in a 5.1 setup to adjust the level output so the listening position is not overwhemled by say the rear surround speaker overriding the front left & right speaker or the most critical the center speaker. The calibration mic uses computer tech to make it easier for the user, no sound pressure calibration is needed as with the test tone setup mentioned earlier. The wireless speaker situation could be possibly waiting for the calibration confirmation, Read any user manual information if available.
Jan 25, 2009 | Sony DAV-DZ100 System
How to create owr own calculater
for all os ? you must use java language! this is the code:
//<applet code="calmayank"height=300 width=300></applet>
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class calmayank extends JApplet
implements ActionListener
JTextField t1;
JButton b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,
b11,b12,b13,b14,b15,b16,b17,b18,b19,b20;
GridLayout gl;
JPanel p1,p2,p3;
public void init()
gl=new GridLayout(5,4);
p1=new JPanel();
p2=new JPanel();
p3=new JPanel();
p1.setLayout(gl);
t1=new JTextField(17);
b1=new JButton("1");
b2=new JButton("2");
b3=new JButton("3");
b4=new JButton("4");
b5=new JButton("5");
b6=new JButton("6");
b7=new JButton("7");
b8=new JButton("8");
b9=new JButton("9");
b10=new JButton("0");
b11=new JButton("+");
b12=new JButton("-");
b13=new JButton("*");
b14=new JButton("/");
b15=new JButton("@");
b16=new JButton("$");
b17=new JButton("%");
b18=new JButton(".");
b19=new JButton("?");
b20=new JButton("=");
p2.add(t1);
p1.add(b1);
p1.add(b2);
p1.add(b3);
p1.add(b4);
p1.add(b5);
p1.add(b6);
p1.add(b7);
p1.add(b8);
p1.add(b9);
p1.add(b10);
p1.add(b11);
p1.add(b12);
p1.add(b13);
p1.add(b14);
p1.add(b15);
p1.add(b16);
p1.add(b17);
p1.add(b18);
p1.add(b19);
p1.add(b20);
p3.add(p2);
p3.add(p1);
getContentPane().add(p3);
b1.addActionListener(this);
b2.addActionListener(this);
b3.addActionListener(this);
b4.addActionListener(this);
b5.addActionListener(this);
b6.addActionListener(this);
b7.addActionListener(this);
b8.addActionListener(this);
b9.addActionListener(this);
public void actionPerformed(ActionEvent e)
if(e.getSource()==b1)
t1.setText("1");
else if(e.getSource()==b2)
t1.setText("2");
else if(e.getSource()==b3)
t1.setText("3");
else if(e.getSource()==b4)
t1.setText("4");
else if(e.getSource()==b5)
t1.setText("5");
else if(e.getSource()==b6)
t1.setText("6");
else if(e.getSource()==b7)
t1.setText("7");
else if(e.getSource()==b8)
t1.setText("8");
else if(e.getSource()==b9)
t1.setText("9");
Dec 15, 2008 | Computers & Internet
Not transmitting through both speakers properly
The UTX-B1 input is not a stereo jack, and the receiver output is also not a stereo jack. Only the receiver Headphone/Monitor jack is stereo.
Not sure if you are sending stereo signals from or to the camcorder. But you can try mono-to-stereo adapter.
Hope it helps!
Jul 16, 2008 | Sony (UWP-S1) Professional Microphone
Utx.dll
I have "Googled" this dll and it seems to some sort of Virus.. malware, some links below.. www.fbmsoftware.com/spyware-net/ Process/uTx_dll/3366/ www.spywaredata.com/spyware/malware/utx.dll.php Do a search of ya files, directories look for any other files utx*.* see if ya get any hits, then see if they are good or bad... and ya may find it's uninstall program
Sep 09, 2007 | Microsoft Windows XP Professional With...
Sony Wireless Mic (Transmitter) UTX-B1
Sounds like some type of manufacturer's flux problem. As an ex-Sony pro dealer we saw something like this years ago. You might want to contact Sony support (industrial or broadcast, not consumer) and see if there is a technical bulletin out on this problem.
May 24, 2007 | Sony (UWP-S1) Professional Microphone
Cameras Logo
487 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
